BAQ Dataview linked to unbound controls?
This code compiles ok. But my grids don’t get populated with any data.
public class Script
	public BAQCombo cmbpartrev;
	DataTable dtPartRevOps;
	EpiDataView dvPartRevOps;
	DataTable dtEcoRevOps;
	EpiDataView dvEcoRevOps;
	BAQDataView bdvEco, bdvPart;
	DataTable dtRevOps;
	EpiDataView dvRevOps;
	private EpiDataView edvPartRevOps;
	private EpiDataView edvEcoRevOps;
		SetupBAQDvs();
// filtered out a bunch of lines here...
public void SetupBAQDvs()
		//Create a EpiDataView to use for filtering
		dtRevOps = new DataTable(); //instantiate DT
		var colMyPart = new DataColumn("Part"); // inst column
		colMyPart.ExtendedProperties["Like"]="Part.PartNum";	//add like for right click open with
		dtRevOps.Columns.Add(colMyPart); // add custom column to DT (repeat for all columns)
		var colMyRev = new DataColumn("Rev"); // inst column
		dtRevOps.Columns.Add(colMyRev); // add custom column to DT (repeat for all columns)
		dtRevOps.Columns.Add(new DataColumn("SysRowId",typeof(Guid))); // add guid column to DT (required)
		var dr = dtRevOps.NewRow(); //inst a new row
		dr["SysRowId"] = Guid.NewGuid(); // just set the guid for the new row
		dtRevOps.Rows.Add(dr); // add the row to the DT to enable fields in the table
		dvRevOps = new EpiDataView(); //inst the EDV
		dvRevOps.dataView = dtRevOps.DefaultView; // set the EDV to the default view of the DT created above (default view is unfiltered view of entire DT)
		oTrans.Add("OpsList",dvRevOps); // adds the EDV to the binding list
		//Publish Changes to Part and Rev columns
		var fromPubPart= "OpsList.Part"; //whenever the listed field changes publish the new value
		oTrans.PublishColumnChange(fromPubPart,"FromPubPart"); //publish the value to otrans
		var fromPub = oTrans.GetPublisher(fromPubPart); //this pulisher 'fromPub' gets the notification when above field changes.
		var fromPubRev= "OpsList.Rev"; //whenever the listed field changes publish the new value
		oTrans.PublishColumnChange(fromPubRev,"FromPubRev"); //publish the value to otrans
		var fromPub2 = oTrans.GetPublisher(fromPubRev); //this pulisher 'fromPub' gets the notification when above field changes.
		//Setup the first BAQDataView
		bdvEco = new BAQDataView("getPartRevOpECO"); //inst the BDV
		oTrans.Add("EcoRevOps",bdvEco); //add the BDV to the binding list (this is an unfiltered BDV. Filter the BDV with Pub/Sub)
		bdvEco.SubscribeToPublisher(fromPub.PublishName,"ECORev_PartNum"); // subscribe BDV to fromPub created above. filer by listed field based on publisher.
		bdvEco.SubscribeToPublisher(fromPub2.PublishName,"ECORev_RevisionNum"); // subscribe BDV to fromPub created above. filer by listed field based on publisher.
		//Setup the Second BAQDataView
		bdvPart = new BAQDataView("EditAnyOp"); //inst the BDV
		oTrans.Add("PartRevOps",bdvPart); //add the BDV to the binding list (this is an unfiltered BDV. Filter the BDV with Pub/Sub)
		bdvPart.SubscribeToPublisher(fromPub.PublishName,"PartRev_PartNum"); // subscribe BDV to fromPub created above. filer by listed field based on publisher.
		bdvPart.SubscribeToPublisher(fromPub2.PublishName,"PartRev_RevisionNum"); // subscribe BDV to fromPub created above. filer by listed field based on publisher.
// filtered some more lines out...
//the function below should populate and display the correct grid as needed. Currently only showing a blank grid.
private void CheckForCheckedOut()
		oTrans.PushStatusText("Looking for checked out part/revs...", false);
		if (bdvEco.dataView.Count > 0)
		{ //Show ECORev
			//MessageBox.Show("Checked Out!");
			epiGridPartRev.Hide();
			epiGridEcoRev.Show();
			epiGridEcoRev.EpiBinding = "EcoRevOps";
			epiGridEcoRev.Text = "This Revision is Checked-Out!";
			epiGridEcoRev.Refresh();
			EpiUltraGrid MyGridEcoRev = ( ( EpiUltraGrid )csm.GetNativeControlReference( "a6178e89-673d-42d8-bf20-879a3a242484" ) );
			UltraGridBand bandEcoRevs = MyGridEcoRev.DisplayLayout.Bands[0];
			bandEcoRevs.Columns[5].Width = 550;
 //set the comment column to be wider
			isCheckedOut.Show();
		else //Show PartRev
			//MessageBox.Show("Not Checked Out!");
			epiGridEcoRev.Hide();
			epiGridPartRev.Show();
			epiGridPartRev.EpiBinding = "PartRevOps";
			epiGridPartRev.Text = "This Revision is Not Checked-Out.";
			epiGridPartRev.Refresh();
			EpiUltraGrid MyGridPartRev = ( ( EpiUltraGrid )csm.GetNativeControlReference( "f19fb3e9-5c6b-4e2b-8d7e-f36c7a37a959" ) );
			UltraGridBand bandPartRevs = MyGridPartRev.DisplayLayout.Bands[0];
			bandPartRevs.Columns[5].Width = 550;
			isCheckedOut.Hide();
	oTrans.PushStatusText("Done!", false);
It doesn’t populate any data when you enter values in the filter and tab out?
Gah! I forgot to set the EpiBinding for my rev field to OpsList. I think it is working now. Thank you so much for your patient help!
yay! the EpiMagic worked!
I am still having troubles with my bdvEco. Once the user enters a part/rev, the function CheckForChecekdOut runs. The first line of this looks at the bdvEco and if there are any rows at all, then the part has been checked out. However, my bdvEco does not seem to get updated showing the checked out part. Do I need to force the bdv to update somehow to show that there are indeed rows checked out?
After I enter the part/rev it looks like my eco grid is getting updated, but my bdvEco still shows a count of 0. If I enter the part/rev a second time, after the tables have been loaded, then my bdvEco does show the correct count. Its like it doesn’t know the count until the grid has been loaded. I have tried adding a refresh before I check the count: epiGridEcoRev.Refresh(); But this didn’t help.
If there’s one thing I love beating… its a dead horse!
