Server Side Exception
BPM runtime caught an unexpected exception of âCryptographicExceptionâ type.
See more info in the Inner Exception section of Exception Details.
Error Detail
Correlation ID: 909e6f8f-00d2-459d-87a7-71ed103828c6
Description: BPM runtime caught an unexpected exception of âCryptographicExceptionâ type.
Program: System.Security.Cryptography.Algorithms.dll
Method: GetPaddingLength
Original Exception Type: CryptographicException
Framework Method: Throw
Framework Line Number: 0
Framework Column Number: 0
Framework Source: Throw at offset 22281712 in file:line:column :0:0
Server Trace Stack: at Internal.Cryptography.UniversalCryptoDecryptor.GetPaddingLength(ReadOnlySpan1 block) at Internal.Cryptography.UniversalCryptoDecryptor.UncheckedTransformFinalBlock(ReadOnlySpan1 inputBuffer, Span1 outputBuffer) at Internal.Cryptography.UniversalCryptoDecryptor.UncheckedTransformFinalBlock(Byte[] inputBuffer, Int32 inputOffset, Int32 inputCount) at Internal.Cryptography.UniversalCryptoTransform.TransformFinalBlock(Byte[] inputBuffer, Int32 inputOffset, Int32 inputCount) at System.Security.Cryptography.CryptoStream.ReadAsyncCore(Memory1 buffer, CancellationToken cancellationToken, Boolean useAsync)
at System.Security.Cryptography.CryptoStream.Read(Byte[] buffer, Int32 offset, Int32 count)
at System.IO.StreamReader.ReadBuffer()
at System.IO.StreamReader.ReadToEnd()
at Epicor.Security.Cryptography.Encryptor.Decrypt(Byte[] cipherBytes, Byte[] key, Byte[] iv) in C:_releases\ICE\ICE4.2.200.27\Source\Shared\Framework\Epicor.ServiceModel\Security\Cryptography\Encryptor.cs:line 106
at Epicor.Customization.Bpm.Ubaq.GetListPostProcessingDirective_401k_Replace_SSN_2FD095DEB03445E8839F250FB5AB04CA.A001_CustomCodeAction()
at Epicor.Customization.Bpm.Ubaq.GetListPostProcessingDirective_401k_Replace_SSN_2FD095DEB03445E8839F250FB5AB04CA.ExecuteCore(Int32 step)
at Epicor.Customization.Bpm.DirectiveBase2.Execute() in C:\_releases\ICE\ICE4.2.200.27\Source\Server\Internal\Lib\Epicor.Customization.Bpm\DirectiveBase.Generic.cs:line 330 at Epicor.Customization.Bpm.DirectiveBase2.Execute(TParam parameters) in C:_releases\ICE\ICE4.2.200.27\Source\Server\Internal\Lib\Epicor.Customization.Bpm\DirectiveBase.Generic.cs:line 222
Client Stack Trace
at Ice.Cloud.ProxyBase1.CallWithCommunicationFailureRetry(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, RestRpcValueSerializer serializer) at Ice.Cloud.ProxyBase1.CallWithMultistepBpmHandling(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Ice.Cloud.ProxyBase1.Call(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy) at Ice.Proxy.BO.DynamicQueryImpl.GetList(DynamicQueryDataSet queryDS, QueryExecutionDataSet executionParams, Int32 pageSize, Int32 absolutePage, Boolean& hasMorePage) at Ice.Adapters.DynamicQueryAdapter.<>c__DisplayClass45_0.<GetList>b__0(DataSet datasetToSend) at Ice.Adapters.DynamicQueryAdapter.ProcessUbaqMethod(String methodName, DataSet updatedDS, Func2 methodExecutor, Boolean refreshQueryResultsDataset)
at Ice.Adapters.DynamicQueryAdapter.GetList(DynamicQueryDataSet queryDS, QueryExecutionDataSet execParams, Int32 pageSize, Int32 absolutePage, Boolean& hasMorePage)
at Ice.UI.App.BAQDesignerEntry.BAQTransaction.TestCallListBckg()
at Ice.UI.App.BAQDesignerEntry.BAQTransaction.<>c__DisplayClass220_0.b__0()
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
Inner Exception
Padding is invalid and cannot be removed.
