Oops - replied to wrong thread - now corrected.
We do a lot of split orders, so this is a problem we have too. I can't solve the problem in a BAQ, but I do solve it in Crystal.
One thing to note - you cannot link to the sales rep table in your BAQ if you are using the technique I suggest.
First, separate out the sales rep ID's into rep1, rep2, rep3, rep4, and rep5. I have formulas I would be willing to share with anyone who is interested in this.
Then, create a list of numbers 1 through 5 in an Excel spreadsheet. Link to this spreadsheet in your Crystal report. Do not link this field of 5 numbers to any other table from your BAQ. This will create five records for each BAQ record, each numbered 1, 2, 3, 4, or 5.
Next, set up a formula for a single field that is the sales rep ID. If the line number is 1, use rep1, if the line number is 2, use rep2, and so forth for the 5 possible reps.
Put the various fields on your report. Suppress any records where the sales rep ID is blank. The line numbers become irrelevant at this point. You can sort by the calculated sales rep ID from the previous step.
If you need more information about the sales reps from the sales rep table, I think you could link that in using ODBC against the Vista/Vantage DB. I just use the ID and that works fine for out purposes. One more thing - if your splits do not add up to 100%, your sales totals will not be correct overall.
This information is a bit sketchy. Let me know if you need more details, or if you want me to repeat my rant about the moronic database analyst who came up with this idiotic database structure.
BTW, I like Steven's idea about breaking apart the rep list in a BPM. It still does not solve the issue of poor database structure, but it is an improvement over what is there now. Ideally, the salesperson splits should be in a separate table. I have thought about how to make that work, but so far have had more important things on my plate. If anyone comes up with that solution, I would like to see it.
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
"The World Leader in Back-lit Mirrors & Mirror TV Technology"
T 425 776-4946
A 11831 Beverly Park Rd, Bldg D, Everett, WA 98204 USA
www.electricmirror.com<http://www.electricmirror.com>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Brian W. Spolarich
Sent: Monday, February 22, 2010 11:04 AM
Subject: RE: [Vantage] Re: Report Errors
This is how the report subsystem works in V8. Has anything changed in E9?
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
bspolarich@...<mailto:bspolarich%40advancedphotonix.com><mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Dines, Tim
Sent: Monday, February 22, 2010 1:37 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
This is something that I run into on a daily basis. If the report does
not produce a preview screen I check the monitor after a few minutes.
Tim Dines
Information Technology
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
Direct: 765-675-5201
Cell: 765-437-1402
Of chouse1000
Sent: Monday, February 22, 2010 1:22 PM
Subject: [Vantage] Re: Report Errors
Does anyone else have this problem?
Cindy
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
"chouse1000" <cindy.house@...> wrote:
nothing to report. In 6.10 the report would come back with an error
message "No records selected for date range." However, I believe that
instead of getting this pop up error message in 8.03, we are just
getting an error message on the System Monitor instead. I have found
this to be true on the following reports: Open RMA Report, Subcontract
Status Report, and the Advance Billing/Deposit Balance Report. Has
anyone else experienced this? I want to make sure that my conversion is
clean.
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
Tim Dines
801 Berryman Pike
Tipton, IN 46072
Cell: 765-437-1402
Of chouse1000
Cindy
>four standard reports on 8.03 that have produced errors when there was
> We are upgrading from 6.10.543 to 8.03.408B and I have seen at least
clean.
> Thanks,
> Cindy House
