We have just worked through the sales order ack issues. Vantage does
have a known bug in the sales order acknowledgement. Have Vantage send
you the latest form. They are supposed to be providing a fix in the
6.00.5.17 release.
Thanks.
dave
National Coupling Company, Inc.
Office: 281.499.2583
Fax: 281.499.5941
Direct: 281.208.6715
Cell: 281.352.2793
Sent: Tuesday, January 06, 2004 3:09 PM
Subject: RE: [Vantage] Crystal Confusion
Getting closer. I am actually working two things at once. BTW V5.2
Crystal
8.5.
I am modifing the Sales Order Acknoledgement (SOform.rpt). I added a VB
Form
to the Order Line with a series of Check Boxes indicating the
Certification
requirments. When I run the report from Vantage I get Error 599. When
I do
a print preview from Crystal the check box fields display but do not
toggle
from false to true when checked.
Not sure if I have a problem in the VB form or the report or both.
We did get the Quote form to finally work though.
Thanks for the help.
Wayne
Sent: Tuesday, January 06, 2004 1:48 PM
Wayne,
In case you did not see Shirley's post - here it is;
When linking two different field types in crystal ie (numeric - alpha)
(alpha - numeric), create a calculated field to convert to the desired
data type. TOTEXT(NUMERIC FIELD) or TONUMBER(ALPHA FIELD). If I recall
correctly it seems to work best when you do your conversion in the
master report to the sub report. Sub report has numeric data in alpha
field. Corresponding field in master report is numeric. In master
report convert your numeric data to alpha using TOTEXT( NUMERIC MASTER
REPORT FIELD) then use the converted field in your link to the sub
report.
Shirley Graver
Systems administrator
Rubber Associates inc
Have a Nice Day,
Dina Hieber
Vamco International, Inc.
Phone (412) 963-7100
Fax; (412) 963-7160
www.vamcointernational.com
_____
Sent: Tuesday, January 06, 2004 2:45 PM
To: 'vantage@yahoogroups.com'
Hello Wayne,
Shirley address this problem in 12/17/03 message. She is the wizard you
seek.
Dan Shallbetter
States Electric Mfg.
Sent: Tuesday, January 06, 2004 1:23 PM
To: 'Vantage User Group'
Subject: [Vantage] Crystal Confusion
Hi group I need HELP!
I am by no means a Crystal Report Wizard. I probably know enough to be
very
dangerous.
I am trying to create a sub report using OrderHed.OrderNum as the link
to
the SubReort.
The Subreport comes up but none of the fields are populated.
When I look at the format of OrderNum on the main report it is a text
string. On the Subreport it is an integer. Is this why? If so how do
I
fix it. If not any other ideas?
By the way this is related to the earlier Quote Report string.
Wayne Katzenberger
VP Engineering
ELECPAC
Phone: 847-639-2307
Fax: 847-639-3830
have
and
HYPERLINK
"http://groups.yahoo.com/group/vantage/files/"http://groups.yahoo.com/gr
oup/vantage/files/.
<HYPERLINK
oup/vantage/files/>
HYPERLINK
"http://groups.yahoo.com/group/vantage/messages"http://groups.yahoo.com/
HYPERLINK
"http://groups.yahoo.com/group/vantage/links"http://groups.yahoo.com/gro
up/vantage/links
_____
Yahoo! Groups Links
HYPERLINK
"http://groups.yahoo.com/group/vantage/"http://groups.yahoo.com/group/va
ntage/
* Your use of Yahoo! Groups is subject to the Yahoo!
<HYPERLINK
"http://docs.yahoo.com/info/terms/"http://docs.yahoo.com/info/terms/>
Terms of Service.
have
and
HYPERLINK
oup/vantage/files/.
HYPERLINK
HYPERLINK
up/vantage/links
Yahoo! Groups Links
HYPERLINK
ntage/
Your use of Yahoo! Groups is subject to:
HYPERLINK
and Crystal Reports and other 'goodies', please goto: HYPERLINK
oup/vantage/files/.
(2) To search through old msg's goto: HYPERLINK
HYPERLINK
up/vantage/links
_____
Yahoo! Groups Links
HYPERLINK
ntage/
HYPERLINK
"mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe"vantage-
* Your use of Yahoo! Groups is subject to the HYPERLINK
"http://docs.yahoo.com/info/terms/"Yahoo! Terms of Service.
Outgoing mail is certified Virus Free.
Checked by AVG Anti-Virus (http://www.grisoft.com).
Version: 7.0.209 / Virus Database: 261.5.6 - Release Date: 1/2/2004
6.00.5.17 release.
Thanks.
dave
Fax: 281.499.5941
Cell: 281.352.2793
Crystal
8.5.
Form
Certification
I do
toggle
Wayne
Wayne,
report.
Shirley Graver
Have a Nice Day,
Dina Hieber
Fax; (412) 963-7160
_____
Hello Wayne,
seek.
Dan Shallbetter
very
dangerous.
to
the SubReort.
I
Wayne Katzenberger
VP Engineering
ELECPAC
Phone: 847-639-2307
Fax: 847-639-3830
have
and
HYPERLINK
oup/vantage/files/.
<HYPERLINK
oup/vantage/files/>
HYPERLINK
HYPERLINK
up/vantage/links
_____
Yahoo! Groups Links
HYPERLINK
ntage/
<HYPERLINK
Terms of Service.
have
and
HYPERLINK
oup/vantage/files/.
HYPERLINK
HYPERLINK
up/vantage/links
Yahoo! Groups Links
HYPERLINK
ntage/
HYPERLINK
oup/vantage/files/.
HYPERLINK
up/vantage/links
_____
Yahoo! Groups Links
HYPERLINK
ntage/
HYPERLINK
