BAQ Nubie question
Cliff, how are you?
It looks, from what you wrote, that you are trying to open a BAQ from the BAQ Report designer and they are totally different files. The general steps to create a BAQ Report are:
1. Create a BAQ (what I call a base query)
2. Create a BAQReport (Through the BAQ Report Designer)
3. Select your previously created BAQ to be the base for your BAQ-Report (I know, I know.... BAQ here, BAQ there is confusing, but you'll get used to it)
4. Test Run your new BAQReport, to generate the Crystal file (*.rpt) in your CustomReports folder in Epicor server location (epicor/mfgsys803/server/reports/CustomReports)
5. Open your automatically-generated Crystal file from Crystal Reports; retrieve the temporary xml file generated by Vantage and placed in: epicor/mfgsysdata/reports/username; design and format your Crystal Report (form)
At the end, (and I always document completed reports with these), you should have a BAQ, a BAQReport, a Crystal file and a Vantage Menu Path.
Hope this helps Cliff.
Roel Martinez
ERP Analyst
SABRE TUBULAR STRUCTURES (tm)
www.sabretubularstructures.com<http://www.sabretubularstructures.com/>
8653 E. Hwy 67 | Alvarado, TX 76009
Phone: 817-852-1700 ext. 11858 | Direct Line: 817-852-1858 |Fax: 817-852-1705
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Cliff Drumeller
Sent: Wednesday, June 16, 2010 10:21 AM
Subject: [Vantage] BAQ Nubie question.
I copied a BAQ and modified it slightly and then created a crystal
report from it. Now when I go to open the BAQ in BAQ Report designer I
get an application error. Column 'FileTypeID' does not belong to table
DynamicQuery and it doesn't open. Where am I going wrong ?
Epicor 9.05.600A
Cliff Drumeller
IT Manager
Phone: 408 954 0200 ex 348
Cell: 408 314 7420
Epicor 9.05.600A
Cliff Drumeller
IT Manager
Cell: 408 314 7420
