BAQ report and SQL views
Absolutely, you can add anything to the Epicor menus.  There is a "program type" when you add new menu items. Select "custom report link" instead of "BAQ report" and it'll open just fine. I have many menu items that simply open web pages on my corporate intranet for various ASP-dashbaords and MSDS info, etc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Neil Buckman
Sent: Friday, February 14, 2014 6:01 PM
Subject: RE: [Vantage] BAQ report and SQL views
Thanks Vic,
I will look at this, although the down side is the report cannot then be run through Epicor - or can it?
Neil Buckman
Information Technology
[Gibson Shopfitters]
DH Gibson Pty Ltd | 205-231 Fairfield Rd | YENNORA NSW 2161
Office 8724 4600 | Direct 8724 4618 | Fax 8724 4604 | Mobile 0413 125 994
nbuckman@...<mailto:nbuckman@...> | www.gibsonshopfitters.com.au <http://www.gibsonshopfitters.com.au/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Saturday, 15 February 2014 12:42 AM
Why don't you just hit the SQL View directly with Crystal? If you want to filter your view's results on the back-end, use SQL Expressions in Crystal.
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com] On Behalf Of nbuckman@...<mailto:nbuckman@...>
Sent: Thursday, February 13, 2014 5:05 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Subject: [Vantage] BAQ report and SQL views
I have an SQL view for which I have created an external BAQ. I can set any criteria in the BAQ and select the data accordingly. However, when I remove those criteria and use the BAQ in a BAQ report, the Options will not work to select data. I get all the data from the view, no matter what options I set. We are on 9.05.700C.
Anyone else experienced this?
I can filter the data in Crystal, but the volume of data returned will just keep increasing and it will become a problem down the track.
- Neil
Notice:This e-mail and any attachments are confidential and are only for the use of the person to whom they are addressed. If you are not the intended recipient please advise the sender by return e-mail and delete the message and any attachments. Any use, interference with, disclosure or copying of this message or any attachments is unauthorised and prohibited. The sender does not warrant that the information is free of a virus or any other defect or error, and any views expressed herein, unless specifically indicated otherwise, are those of the individual sender.
The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
P Please consider our shared environment before printing this communication.
 -  Neil
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of nbuckman@...
 -  Neil
Thanks Vic,
Neil Buckman
- Neil
