Hi,
I wish that was true. Its a very complex report I am trying to achieve and with the limitations of the BAQ(speed and complexities of queries)Â it is impossible. :(
Sent: Fri, 30 October, 2009 13:18:41
Subject: RE: [Vantage] Re: Dashboard Crystal Report - From Menu Item
Â
If you say so. You can do all of this with a BAQ report. :-)
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@advanced photonix. com ~ 734-864-5618 ~ www.advancedphotoni x.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of brychanwilliams
Sent: Friday, October 30, 2009 8:58 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Re: Dashboard Crystal Report - From Menu Item
Hi,
Yeb you are right. The dashboard report relies on the data within the dashboard rather than generating an xml file. So although you can attached the report, as it doesn't go through the process server there is no or incorrect data. A bit of shame....
Â
Hi,
--- In vantage@yahoogroups .com, "Brian W. Spolarich " <bspolarich@ ...> wrote:
> Yeah but I think he's asking a different question.
> He's created a Dashboard report - a crystal report that uses dashboard data for its input.
> I don't think you can make that directly available on the menu and I'm not sure it logically makes sense. A dashboard ultimately uses BAQs for its data, and BAQ Reports are the way to do custom reporting. The Dashboard report just says 'take the current data in my dashboard and send the XML to the report viewer along with this RPT file'. That requires you to be in a 'dashboard context' I would think.
> -bws
> Â Â Â Â bspolarich@. .. ~ 734-864-5618 ~ www.advancedphotoni x.com
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Vic Drecchio
> Sent: Friday, October 30, 2009 8:30 AM
> Subject: RE: [Vantage] Dashboard Crystal Report - From Menu Item
> Are you familiar with Menu Maintenance?
> It's very easy. Open Menu Maintenance and navigate to the desired menu
> tree and "Add New Menu" and for Program Type choose Custom Report.
> You can add *any* executable to the Vantage menu.
> I add intranet website URLs that open in IE for many of our dashboards.
> Vic
> Of brychanwilliams
> Sent: Friday, October 30, 2009 5:34 AM
> Subject: [Vantage] Dashboard Crystal Report - From Menu Item
> Hi,
> I have created dashboard crystal report, Is it possible to execute it
> from a menu item?
> Thanks
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups. yahoo.com/ group/vantage/ files/.
> http://groups. yahoo.com/ group/vantage/ messages
> http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups. yahoo.com/ group/vantage/ files/.
> (2) To search through old msg's goto: http://groups. yahoo.com/ group/vantage/ messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
