Perfect.
Thank you.
Thank you.
--- In vantage@yahoogroups.com, Dan Shallbetter <dans@s...> wrote:
> Kelly,
> If you are trying to delete spaces in front of the sequence number
you might
> try something like this "*"+ trimleft(JobMtl.AsmSeq) + "*"
> Dan Shallbetter
> States Electric Mfg.
> -----Original Message-----
> From: Kelly Wendorff [mailto:kelly.wendorff@s...]
> Sent: Thursday, July 01, 2004 1:58 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Bar Code Help
> I am trying to barcode the JobMtl.AsmSeq field on our Traveler.
> This field is a 4 character string. After using a formula to insert
> asterisk around the field, the bar code looks like this
> *___1* (3 spaces before the numeric character).
> Crystal displays this field as two serpate bar coded fields (with a
space
> between) which my gun (PSC Powerscan LR) won't read. If I replace
the
> spaces with commas (*,,,1*), it works.
> Ideally, I would like the field to look appear as *1* or *12* if a
two
> character field.
> I'm sure that I need to convert this string to another type of
field, but
> that's the extent of my knowledge.
> Can anyone help?
> TIA,
> Kelly Wendorff
> Cost Accounting Manager
> SteelCraft Corporation
> 105 SteelCraft Drive
> Hartford, WI 53027
> 262.673.6770
> 262.673.4380 (Fax)
> www.scc-wi.com
