Bar Code Job + Asm + Seq Help
Glad it works.
Just for a note $M is enter just as <ctrl>M is, and $I is tab just as
<ctrl>I is.
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of wendorff1
Sent: Wednesday, April 27, 2005 5:00 PM
Subject: [Vantage] Re: Bar Code Job + Asm + Seq Help
I assume that the $M = Tab. When I scan the bar code, I get
"39553$M2$M10". It's not tabbing properly. Is my bar code gun not
configured properly?
You guys have been a great help. Thanks!
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@v...> wrote:
> Frank that is just about it...
> The specific code is this...
> "*" & Trim ({JOBOPER.JOBNUM}) & "$M" & Trim ({JOBOPER.ASMSEQ}) &
"$M" & Trim
> ({JOBOPER.OPRSEQ}) & "$M" & "$M" & "*"
> Good luck Kelly,
> Aaron Hoyt
> Vantage Plastics
> Of Frank Zeigafuse
> Sent: Wednesday, April 27, 2005 3:49 PM
> Subject: RE: [Vantage] Bar Code Job + Asm + Seq Help
> Where are they on the screen?
> Sorry for making it sound simple but this is what I think you need
to do.
> Look at collection screen and figure out what you tabs or enters
which are
> chr(13)+chr(10) then create the formula in crystal like
{jobasy.jobnum}+chr(10)+chr(13)+{jobasy.assy}+chr(10)+chr(13)+{jobassy.seq}
> This is more of a thought mind you not real code, but it think if
you play
> with it for a couple of minutes it should work. I know a couple of
days on
> the list they published the list of characters for the bar codes.
> Frank Zeigafuse
> Innovative Office Products
> General Manager
> Direct Phone: 610-559-6369
> Email: fzeigafuse@L...
> From: wendorff1 [mailto:kelly.wendorff@s...]
> Sent: Wednesday, April 27, 2005 3:33 PM
> Subject: [Vantage] Bar Code Job + Asm + Seq Help
> I know this has been discussed before but I've never been clear on
exactly
> how to do this.
> I'm trying to create a single bar code on the Traveler (using
Crystal) that
> will enter the Job, Assembly and Sequence codes into the Plant Floor
labor
> collection module.
> Can someone who has done this help me out?
> TIA,
> Kelly
must have
Builder and
> Yahoo! Groups Links
must have
Builder and
> Yahoo! Groups Links
Yahoo! Groups Links
exactly how to do this.
I'm trying to create a single bar code on the Traveler (using Crystal)
that will enter the Job, Assembly and Sequence codes into the Plant
Floor labor collection module.
TIA,
Kelly
Sorry for making it sound simple but this is what I think you need to do.
Look at collection screen and figure out what you tabs or enters which are
This is more of a thought mind you not real code, but it think if you play
with it for a couple of minutes it should work. I know a couple of days on
Frank Zeigafuse
General Manager
Email: fzeigafuse@...
I know this has been discussed before but I've never been clear on exactly
how to do this.
I'm trying to create a single bar code on the Traveler (using Crystal) that
will enter the Job, Assembly and Sequence codes into the Plant Floor labor
collection module.
TIA,
Kelly
Yahoo! Groups Links
"*" & Trim ({JOBOPER.JOBNUM}) & "$M" & Trim ({JOBOPER.ASMSEQ}) & "$M" & Trim
Good luck Kelly,
Aaron Hoyt
Vantage Plastics
Of Frank Zeigafuse
Frank Zeigafuse
General Manager
how to do this.
collection module.
TIA,
Kelly
Yahoo! Groups Links
Yahoo! Groups Links
One other hint....some scanners require "extended ASCII" to be turned on to read $M and such. Usually there is a barcode in the manual to scan that turns it on IF it is not on by default. If the scan of the barcode from Aaron's code does not work check the manual for how to be sure extended ASCII is on before assuming something is wrong with the code.
-Todd C.
Good luck Kelly,
Aaron Hoyt
Vantage Plastics
Of Frank Zeigafuse
Frank Zeigafuse
General Manager
how to do this.
collection module.
TIA,
Kelly
Yahoo! Groups Links
Yahoo! Groups Links
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
"$M" & Trim
> Good luck Kelly,
> Aaron Hoyt
> Vantage Plastics
> Of Frank Zeigafuse
to do.
which are
you play
days on
> Frank Zeigafuse
> General Manager
exactly
> how to do this.
Crystal) that
labor
> collection module.
> TIA,
> Kelly
must have
Builder and
> Yahoo! Groups Links
must have
Builder and
> Yahoo! Groups Links
I should have read this before posting! Thanks Todd, I'll give it a try.
Kelly
> -Todd C.
> From: Aaron Hoyt [mailto:aaron.hoyt@v...]
"$M" & Trim
> Good luck Kelly,
> Aaron Hoyt
> Vantage Plastics
> Of Frank Zeigafuse
to do.
which are
you play
days on
> Frank Zeigafuse
> General Manager
exactly
> how to do this.
Crystal) that
labor
> collection module.
> TIA,
> Kelly
must have
Builder and
> Yahoo! Groups Links
must have
Builder and
> Yahoo! Groups Links
access. )
> _____
> Yahoo! Groups Links
I enabed ASCII and it works perfectly. Thanks for all the help!!
Kelly
try.
> Kelly
> > -Todd C.
> "$M" & Trim
> > Good luck Kelly,
> > Aaron Hoyt
> > Vantage Plastics
Behalf
> > Of Frank Zeigafuse
> to do.
> which are
> you play
> days on
> > Frank Zeigafuse
> > General Manager
> exactly
> > how to do this.
> Crystal) that
> labor
> > collection module.
> > TIA,
> > Kelly
> must have
> Builder and
> > Yahoo! Groups Links
> must have
> Builder and
> > Yahoo! Groups Links
> access. )
> > _____
> > Yahoo! Groups Links
