Barcode problem - Epicor 905.700C - SOLVED
Haha! I finally solved one! Two years on the board. :)
Can I get an avatar now?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Neil Buckman
Sent: Tuesday, January 22, 2013 3:43 PM
Subject: RE: [Vantage] Barcode problem - Epicor 905.700C - SOLVED
Thanks Tom,
That did the trick! Magic. I don't need to reprint 3500 rack labels!
Your willingness to help is much appreciated.
- Neil
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Tom J. Christie
Sent: Wednesday, 23 January 2013 2:55 AM
Go into the datawedge and add a delay between keystrokes. 5ms should be about right. Basically you want to slow it down a little. This worked for us.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of nbuckman@...<mailto:nbuckman%40ymail.com>
Sent: Monday, January 21, 2013 10:41 PM
Subject: [Vantage] Barcode problem - Epicor 905.700C
Hello,
When I scan a code that begins with a letter, that first letter is dropped in the Epicor software. However the same barcode scanned with the same scanner in any other program is fine.
For example, I scan a barcode "X12B2" and I get "12B2". I can manually enter the whole code and it is accepted. I tested this in several fields in several functions and it seems it just doesn't like leading alpha characters.
I tested with Code 39 and Code 128. I am using a Motorola 9090 with WM 6.1 and Datawedge software.
Does anyone know a solution to this, or has anyone else experienced this?
- Neil Buckman
Notice:This e-mail and any attachments are confidential and are only for the use of the person to whom they are addressed. If you are not the intended recipient please advise the sender by return e-mail and delete the message and any attachments. Any use, interference with, disclosure or copying of this message or any attachments is unauthorised and prohibited. The sender does not warrant that the information is free of a virus or any other defect or error, and any views expressed herein, unless specifically indicated otherwise, are those of the individual sender.
The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
P Please consider our shared environment before printing this communication.
Thanks Tom,
- Neil
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tom J. Christie
Hello,
- Neil Buckman
