Hi Eric,
I'm interested in this problem. Did you get any off-line help on it?
Steve Ashton
Database Specialist
Decoustics Limited
65 Disco Road
Toronto, Ontario
Canada M9W 1M2
T (647) 259-4260
F (416) 679-8838
sashton@... <mailto:sashton@...>
Steve.Ashton@... <mailto:Steve.Ashton2@...>
Of homestyleindustries
Sent: Thursday, January 29, 2009 10:29 AM
Subject: [Vantage] Re: Best way to handle plasma cutting jobs
Andrew,
It depends. Typically most of the parts would be for jobs but for
utilization as well as labor purposes we will fill the sheet with
other parts for stock. This way the operator doesn't have to remove a
partially cut sheet, and put it in stock and hope to use it later.
There are other times that the sheet will be filled with nothing but
parts for a job. Yet, at no point will we ever cut all parts on one
sheet for inventory.
Eric
"Andrew Best" <abest@...> wrote:
Behalf
Steve Ashton
Database Specialist
Decoustics Limited
65 Disco Road
Toronto, Ontario
Canada M9W 1M2
T (647) 259-4260
F (416) 679-8838
Andrew,
Eric
>or
> When you are plasma cutting, are you cutting parts for specific jobs
> are you cutting plasma cut parts to stock?[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Regards,
> Andrew Best
> Kice Industries, Inc.
> P(316)744-7151
> F(316)295-2412
Behalf
> Of Tim RussellWe
> Sent: Thursday, January 29, 2009 7:21 AM
> Our business is distribution of plastic sheet. We cut the sheet into
> pieces (all have 4 corners) based upon the needs of our customers.
> don't care about the parts we cut the sheet into so we created apart
> in our inventory called CutPart and we set up Jobs to make 1 CutPartnecessary
> all day long. We then issue the required material and labor
> to cut the cutomers parts, then we actually only ship 1 CutPart off<mailto:vantage%40yahoogroups.com> ,
> each Job to the customer.
> Works very well once you get everyone to understand the process. Let
> me know if you would like to discuss our process further.
> Tim
> "homestyleindustries"does
> <homestyleindustries@> wrote:
> > I am coming closer and closer to our go live date and need some
> > advice. I am implementing Vantage at a metal manufacturer that
> aparts/sheet
> > lot of jobs on a plasma cutter. There will be a lot of different
> > parts that come off of one piece of sheet metal (10 or 12
> > at most). What is the best way to handle this in terms of jobs? Ihandle
> > don't see how setting up a job for each will really work with MES
> > (operator would spend more time clocking into jobs than actually
> > cutting). Any other plasma cutter users out there? How do you
> > this?[Non-text portions of this message have been removed]
> > Thanks in advance
> > Eric
