Erwin,
I would recommend you don't let the system backflush multi part jobs. Its logic to figure out what to backflush doesn't hold up when you book in amounts to stock that would otherwise not consist of 1 "Cycle" on the machine, even then its a bit flaky. Furthermore, if you auto receive into inventory and then amend the labour record qty for some reason the system just books into stock the new finished amount and doesn't "Undo" the previous amount(Still happens in E9).
With all of the above faulty logic in the mod this will cause issues with Cost of Sales and your balance sheet. The work around ATM is to do everything manually.
Test this very well!
We are on Vantage 8.3.408b.
If you have any questions feel free to shoot me an email.
--- In vantage@yahoogroups.com, "erwin" <erwinjw@...> wrote:
> Hi
> We do not use backflushing, yet, it is something we are about to investigate, as we are moving to pre-configured orders coming off the web, we would create the sales order, raise the job and auto-close it, backflushing as we go. At the moment it is a manual process.
> --- In vantage@yahoogroups.com, "markbetts66" <mbetts@> wrote:
> > Earwin,
> > Which version of Vantage are you running? We use the Advanced Production Module to create concurrent multi part jobs but we have hit loads of bugs with the back flushing of materials.
> > Do you have and issue booking in multi-part jobs scrap qty? In our version of Vantage you CANNOT just book scrap parts from jobs. Ive also noticed it booking in the same item multiple times if using auto receive...
> > --- In vantage@yahoogroups.com, "erwin" <erwinjw@> wrote:
> > > Hi
> > > We use the Job Parts functionality, we create a composite bom, since all the parts go through the same ops and pro-rata the materials as required. The final parts are booked away under their own part numbers.
> > > erwin
> > > --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > > > Hi James,
> > > > > 1 job a month for parts to stock instead of 16.
> > > > Multiple part numbers produced from one job?
> > > > I have seen the question before, but never a solution.
> > > > >job for the subassy
> > > > >jobs to stock.
> > > > Since the part number is key to the job entry screen...
> > > > There is always one job for each part number (as far as I know).
> > > > If you do find a way to accomplish multiple part numbers from one job, please share it here.
> > > > Thanks
> > > > --- In vantage@yahoogroups.com, "jamesd" <jdaniel1127@> wrote:
> > > > > Yesterday I got the license codes for my Vantage 8 (looking to go to 9 later this year), it lists the advanced production module. would this help me do this multiple parts on one job easier?
> > > > > > They would go to stock. I have a final assy that is serialized and we currently have a flat BOM and are trying to make it indented with sub
> > > > > > assys. Some of them I want to make a job for the subassy and put it into the final assy and others will be jobs to stock. we don't do to order jobs. Would like to make 1 job a month for parts to stock instead of 16.. Hope this helps clarify the issue.
> > > > > > James
> > > > > > --- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@> wrote:
> > > > > > > Hi James,
> > > > > > > > 8.03.408b
> > > > > > > > We want to create a monthly job with 16 different parts in it, like a batch job. We also don't have APS... We don't want to have to create a seperate job for each part.
> > > > > > > And where do you want these 16 parts to go? Stock? A shipment? Another Job?
> > > > > > > Mark W.
