BOM Cost Report - Material Total Not adding up to Total Material Cost for Parent
Hello All,
I print the BOM cost report and it lists all the materials needed and their extended amounts and material costs…
When I add them all up, they do not equal the total mtl cost for the parent part that is displayed at the bottom of the report. Shouldn’t they add up?
Am I misunderstanding something?
-Utah
Yes, they should add up. It will be hard without seeing an example, at least for me. The only thing I can think of is if you have a fixed cost, it will show the total cost for the lot size, so then it won’t add up unless your lot size is still defaulted to 1. You might try looking at the costing on the method tracker. If you go to actions and view costs it gives you a breakdown of the costs by material. That might give you a clue, though it doesn’t show the lot size or what parts are fixed quantity either.
Good luck! :slight_smile:
I saw what was going on, thank you Dean! However, I do have a slight rounding issue.
But it’s ALMOST* perfect.
Hi,
We are having the same issue. How did you fixed this?
Appreciate any help. Thanks.
Cheers,
