Yes. All modern, scalable multi user systems tend to use temp tables in the client to improve perceived UI response time & keep control of when 'real' table records are written.
It's not a new concept as even word processors and spreadsheet apps in the 80's quickly adopted it so only visible (cells in a spreadsheet for instance) would be immediately updated to reflect a formula recalc (with the others awaiting less intrusive time via background processing). - THEN the apps would update the 'real' data layer (that you would ultimately save).
This fact is one of the three big selling points of BPM over client VB (behavior modifying) customization. BPMs can be triggered by tt (temp) table events whereas as VB customizations generally cannot. (You can trick VB into effectively supporting this but it is a pain and adds yet more app slowing code).
Rob
Rob
--- On Fri, 12/5/08, Bill Jackson <fujijapman@...> wrote:
Subject: Re: [Vantage] BPM & 4GL
Date: Friday, December 5, 2008, 8:39 AM
 Would there be a 'temp table' (ttPart) being used by Vantage when revising parameters for an 'Existing' part?
I'd have to guess it has something to do with 'creating' a new Part vs updating an existing Part.
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Wednesday, December 3, 2008 2:27:05 PM
Subject: [Vantage] BPM & 4GL
Vantage 8.03.406
Looking for a little help. Thought this was an easy one but it
doesn't seem to fire exactly how I thought.
I want to assign a Material Burden % to 'Purchased' part types. I
also want to make sure that 'Manufactured' part types remain at 0. I
have set up a Pre-processing BPM. Below is the 4GL I am running...
For each ttPart where (ttPart.RowMod = 'A' or ttPart.RowMod = 'U' and
ttPart.TypeCode = 'M') no-lock:
Assign ttPart.MtlBurRate = 0.
End.
ttPart.TypeCode = 'P') no-lock:
Assign ttPart.MtlBurRate = 20.
End.
This works when entering a new 'Purchased' part. This works when
entering a new 'Manufactured' part. This works when changing
a 'Manufactured' part to 'Purchased'. It DOES NOT work when changing
from 'Purchased' to 'Manufactured' .
Thoughts?
Jeff
