found it in a bpm for part update, thanks..
----- Original Message -----
Sent: Saturday, March 17, 2012 4:29:18 PM
Subject: Re: [Vantage] Re: Part Maintenance
Â
ok, let me look at that and see if there is a BPM someplace setting it. I haven't dealt with those yet. Have been focused on BAQ's, Dashboards and Crystal reports...
Sent: Saturday, March 17, 2012 11:40:51 AM
Subject: [Vantage] Re: Part Maintenance
Â
BPMs not copied to fresh Vantage install.....
--- In vantage@yahoogroups.com , "b_ordway" <cooner_55421@...> wrote:
> It's working on a backup, that is strange. Would running a backup/restore fix any errors? Are you progress? Have you tried rebuilding indexes on the live database.
> Also I've seen job records get into "state" where they don't update correctly. I've been able to clear some of these by toggling field values. Maybe the same thing can happen with parts? Can you try changing a few like nonstock, qty bearing, etc...
> --- In vantage@yahoogroups.com , jdaniel1127@ wrote:
> > What makes it even more strange is that backed up our database, installed progress and vantage on another server, restored the database backup and that one let's me change it and it stays changed????
> > From: "John Driggers" <waffqle@>
> > Sent: Friday, March 16, 2012 10:09:05 AM
> > We ran into this in 8. It's been a few years, but I believe we ended up
> > just writing a bit of 4gl to go update them.
> > On Fri, Mar 16, 2012 at 8:26 AM, b_ordway <cooner_55421@> wrote:
> > > >as soon as I tab out of the field it changes back to avg??
> > > I wonder if you have a form customization or BPM in place?
> > > That doesn't sound like default behavior to me.
> > > --- In vantage@yahoogroups.com , "jamesd" <jdaniel1127@> wrote:
> > > > 8.03.408B on Progress
> > > > We want to change parts from avg cost to std cost. If I zero out the qty
> > > and try to go int part maintenance and change it from avg to std in the
> > > cost field as soon as I tab out of the field it changes back to avg?? not
> > > sure what would cause that? is there something else that needs changed
> > > first to allow this??
> > > > Thanks,
> > > > James
> > > ÂÂ
> > *John Driggers*
> > *High End Dev, System Design, Profit Drinking*
> > **:: 904.404.9233*
> > *:: waffqle@*
> > *:: NO FAXES*
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:  You must have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/. ÂÂ
> > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo ! Groups Links
