BPM QuoteDtl.Update giving me an unexpected message V8.03.409C
Hi,
Wondering if anyone has seen this before.
If I add a query condition to a Quote.Update BPM, I am getting the following error message
Exception caught in: Epicor.Mfg.BO.Quote
Error Detail
Message: The field ttQuoteDtl.AnalysisCdDescription does not have a valid data type.
Type: Error
Program: bo/DynamicQuery.p
Method: buildTempTable
Table: SelectedField
Row:
Field:
Stack Trace
   at Epicor.Mfg.Proxy.QuoteImpl.Update(QuoteDataSet ds)
   at Epicor.Mfg.UI.Adapters.QuoteAdapter.Update()
   at Epicor.Mfg.UI.App.QuoteEntry.Transaction.Update()
*** Here are my BPM details for the Quote.Update method directive
PreProcess Condition:
ttQuoteDtl.OrderQty field has been changed from any top any  (this is OK, no error)
AND
number of rows in the "QtyCheck" query is not less than 1
-- QtyCheck query details:
---- for each ttQuoteDtl no-lock  where  ttQuoteDtl.OrderQty = ttQuoteDtl.SellingExpectedQty
-------- (when this condtion is added, the ttQuoteDtl.AnalysisCdDescription error is generated after saving a quote change)
PreProcess Action:
Show informational message
*** end BPM details
The "ttQuoteDtl.AnalysisCdDescription"error only displays when I add a condition that uses a
condition like "number of rows in the designed query is not equal less than 1.
The error will then pops up when I save the quote.. after any field is changed.
Experiemented with a post process directive & getting the same behavior.
Thanks in advance
