BPM To Stop Unapproved Revision in Quote
Then do it in the post-processing method using the built in error handler that will halt the change.
Michael Brown
Master Scheduler / Programmer
D&S Manufacturing
715-284-5376 Ext. 344
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of gabelebron07
Sent: Tuesday, February 26, 2013 1:22 PM
Subject: [Vantage] Re: BPM To Stop Unapproved Revision in Quote
not sure what you mean. the condition I made is a pre-proccessing that looks at QuoteDtl.RevisionNum field to make sure its not blank only issue is it looks at it before it has a change to populate if there is a approved rev
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Mike Brown wrote:
> You would need a pre-processing request as well looking to see if the correct revision is populated. If not then proceed to the post processing error.
> Michael Brown
> D&S Manufacturing
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of gabelebron07
> Sent: Tuesday, February 26, 2013 11:40 AM
> Subject: [Vantage] BPM To Stop Unapproved Revision in Quote
> Ok I Started a BPM to restrict from quoting a part with no unapproved
> rev.
> I am having a little trouble trying to find what Method to use. Right
> now I am trying to use
> Epicor.Mfg.BO.Quote
> Update
> because it seems to follow right after I add the part
> I am using the conditions that's only seems to be available in pre
> or base not in post
> the specified field of the changed row is equal to the specified
> expression
> (the QuoteDtl.RevisionNum field of the changed row is equal to the
> String ("") expression)
> Now even if I have a part with an approved Rev it still seems to still
> error out because it seems to see it blank before the system has time to
> populate it with the unapproved rev. But I can't seem to find a way
> to right a condition in post processing or find a method after the fact.
rev.
<businessObject>Epicor.Mfg.BO.Quote</businessObject>
<methodName>Update</methodName>
or base not in post
expression
Michael Brown
D&S Manufacturing
rev.
Epicor.Mfg.BO.Quote
Update
or base not in post
expression
> Michael Brown
> D&S Manufacturing
> rev.
> Epicor.Mfg.BO.Quote
> Update
> or base not in post
> expression
We had to use ABl code due to the fact we sometimes sell purchased parts without revisions and we also allow parts on the fly to not have a revision. Here is the code if you want tot ry it
Â
Â
Â
Â
Â
Â
Â
/* informational message for missing revision. */
for each ttorderdtl:
 if (ttorderdtl.revisionnum = ? or ttorderdtl.revisionnum = " ") and (ttorderdtl.orderline > 0) then do:
  for each part where part.Company = ttorderdtl.company and part.PartNum = ttorderdtl.PartNum and Part.TypeCode = "M" no-lock.
  find orderdtl where orderdtl.company = ttorderdtl.company and orderdtl.OrderNum = ttorderdtl.ordernum and orderdtl.OrderLine = ttorderdtl.orderline no-lock no-error.
  if not avail(orderdtl) then do:
  End.
   for each orderdtl where orderdtl.company = ttorderdtl.company and orderdtl.OrderNum = ttorderdtl.ordernum and orderdtl.OrderLine = ttorderdtl.orderline no-lock.
    if orderdtl.PartNum <> ttorderdtl.partNum then do:
     define variable body2 as character no-undo.
     assign body2 = "Manufactured part " + ttorderdtl.partnum + " is missing revision. ".
  Â
     {lib/PublishInfoMsg.i &InfoMsg = body2
          &InfoSeverity  = {&MESSAGE_INFO}
          &BOName        = "'SalesOrder'"
          &BOMethod  = "'Update'"
          &UserIdent  = DCD-USERID
          &Company  = CUR-COMP
          &Plant  = CUR-PLANT
          &DisplayMode  = {&MESSAGE_DISP_ALONE}}
    End.
   End.
  End. /* end for each part */
 End. /*end for if ttorderdtl.*/
 if (ttorderdtl.revisionnum = ? or ttorderdtl.revisionnum = " ") and (ttorderdtl.orderline = 0) then do:
     define variable body3 as character no-undo.
     assign body3 = "Manufactured part " + ttorderdtl.partnum + " is missing revision. ".
  Â
     {lib/PublishInfoMsg.i &InfoMsg = body3
          &Company  = CUR-COMP
          &Plant  = CUR-PLANT
end. /* end for each buffer */
Sent: Tuesday, February 26, 2013 2:21 PM
Â
> Michael Brown
> D&S Manufacturing
> From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of gabelebron07
> To: mailto:vantage%40yahoogroups.com
> rev.
> Epicor.Mfg.BO.Quote
> Update
> or base not in post
> expression
