Quote or sell and unapproved Rev
Cool I think that would work perfect.. i just need to make sure there
never more than one approved Rev.
I tried creating a BPM under Pre-Processing using condition
(the QuoteDtl.RevisionNum field of the changed row is equal to the ?
expression)
then show informational message under action
I get nothing
But when I remove the Condition the action message appears. Do I have
the Condition right?
--- In vantage@yahoogroups.com, Mark Wagner <mjfw2003@...> wrote:
> You will need to write a BPM to do this, there are no inherent
settings that you can check for this
> Â
> If the part is rev controlled and the rev is unapproved, the rev field
will be blank when the order is created. You can write a BPM that will
not allow the order line to be created if the rev field is blank.
> From: gabelebron07 gabe.lebron@...
> To: vantage@yahoogroups.com
> Sent: Monday, February 25, 2013 2:04 PM
> Subject: [Vantage] Quote or sell and unapproved Rev
> Â
> I am using the latest version of build 701. I wanted to see if I can
stop sales from sell or quoting an unapproved revision with no success.
Wondering if there was something in the system I am missing. I wish that
unapproved rev cant not be sold
I am using the latest version of build 701. I wanted to see if I can stop sales from sell or quoting an unapproved revision with no success. Wondering if there was something in the system I am missing. I wish that unapproved rev cant not be sold
You will need to write a BPM to do this, there are no inherent settings that you can check for this
Â
If the part is rev controlled and the rev is unapproved, the rev field will be blank when the order is created. You can write a BPM that will not allow the order line to be created if the rev field is blank.
Â
