Good catch! I didn't even see that when I was looking at the code! You're
definitely right on that one.
On Wed, Jun 6, 2012 at 4:56 PM, Kirstin Brandt
<kirstin.brandt@...>wrote:
*John Driggers*
*High End Dev, System Design, Profit Drinking*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
> Did you try it without the quotes? It looks to me like you're comparing
> joboper.SetUpCrewSize with the string "crewS" and not the value of the
> variable crewS.
> --- In vantage@yahoogroups.com, "daniellaidig" <daniellaidig@...> wrote:
> > I am trying to use a query in BPM along with a variable. I pasted a
> sample of
> > some simplified code that i was trying to test below. I defined a
> variable crewS
> > and assigned it 10. then i run a query to find my joboper with a setup
> crew less
> > than this. I understand i could eliminate the variable setting in this
> example,
> > but i am trying to figure out how it works.
> > This code compiles but it never returns any rows.
> > for each ttLaborDtl , each joboper where ttLaborDtl.JobNum =
> joboper.JobNum and
> > ttLaborDtl.OprSeq = joboper.OprSeq:
> > define variable crewS as Integer no-undo
> > ASSIGN crewS = 10
> > END
> joboper.JobNum and
> > joboper.SetUpCrewSize < 'crewS'
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
