[BULK] Epicor 9 - BAQ Help
PartBin records are not persistent. They only exist if O/h is not zero. When a qty is received or transfered in the whse bin that was previosuly zer for the part, the partbin record is recreated.
You have two choices:
Either create your part to partbin join as outer (showing ALL part records whether there is a partbin record or not),
Or utilize PartBinInfo. Intended as a Bin level KanBan enabling field, just filling out some of the info (whse & Bin) is enough to make a permanent part-bin relationship.
The data table contains O/H data that DOES persist if o/h he zero.
Rob
Â
Sent: Friday, June 19, 2009 5:29:06 AM
Subject: Re: [BULK] Re: [Vantage] Epicor 9 - BAQ Help
Hi,
I have set up a BAQ that will display the Part, Description and OnHandQty.
I have linked the Part as the parent table with the PartBin as the child.
I can get it to display everything EXCEPT ...
When the BIN has a qty of Zero it will not show. If it has a positive or negative figure it displays.
Does anyone know how I can get it to display the Bin qty for ANY qty incl Zero?
Cheers,
CHRIS
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Monday, 15 June, 2009 15:57:18
Hi Cliff,
That's almost there actually.
However, it now only displays if a bin has a qty. If qty=0 the bin or part doesnt show.
Sent: Monday, 15 June, 2009 15:49:00
Subject: RE: [BULK] Re: [Vantage] Epicor 9 - BAQ Help
Try making partbin your primary table and then linking part for your
description, etc.
Cliff Drumeller
IT Manager
Mass Precision, Inc.
408 786 0348
408 314 7420 cell
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of Chris Thompson
Sent: Monday, June 15, 2009 5:18 AM
Subject: [BULK] Re: [Vantage] Epicor 9 - BAQ Help
Importance: Low
I have tried that, but as soon as I introduce the PartAlloc table to the
phrase builder, when I Analyse, it returns no results as if there is a
conflict between the two table.
I have had something similar where I wanted to see Part No, Weight,
Whse, Bin, but as soon as I added the PartBin table to the Phrasebuilder
it returned no results.
Cheers.
<mailto:sgotschall% 40yahoo.com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Sent: Monday, 15 June, 2009 12:59:28
Subject: Re: [Vantage] Epicor 9 - BAQ Help
I think you are going to have to pull in the PartAlloc table also and
subtract the allocations from the on hand quantities.
Sent: Monday, June 15, 2009 6:41:18 AM
Subject: [Vantage] Epicor 9 - BAQ Help
Hi,
I am trying to write a simple (so I thought) BAQ which I want to use
with a Quick Search.
I want it to display the following:
Part Number | Description | Net Weight | On Hand Qty | Available
Qty
This way, before the part is even added to a SO or Quote, the user in
our Sales Department can see if we have the part available.
I have written a BAQ with the PART and PARTWHSE tables and can
sucessfully display the first 4 columns on my quick search/BAQ, however,
I am struggling to get the 5th column to display.
Any help would be greatly appreciated.
Regards,
CHRIS THOMPSON
Hi,
I am trying to write a simple (so I thought) BAQ which I want to use with a Quick Search.
Part Number | Description | Net Weight | On Hand Qty | Available Qty
This way, before the part is even added to a SO or Quote, the user in our Sales Department can see if we have the part available.
I have written a BAQ with the PART and PARTWHSE tables and can sucessfully display the first 4 columns on my quick search/BAQ, however, I am struggling to get the 5th column to display.
Regards,
CHRIS THOMPSON
I think you are going to have to pull in the PartAlloc table also and subtract the allocations from the on hand quantities.
Hi,
Regards,
CHRIS THOMPSON
I have tried that, but as soon as I introduce the PartAlloc table to the phrase builder, when I Analyse, it returns no results as if there is a conflict between the two table.
I have had something similar where I wanted to see Part No, Weight, Whse, Bin, but as soon as I added the PartBin table to the Phrasebuilder it returned no results.
Cheers.
Hi,
Regards,
CHRIS THOMPSON
I see you are on 9. I am on 8.03.407a, but I don't think it will make to much of a difference. You will need to do an outer join on the PartAlloc table, but after looking at mine, there is no information in it. I do see that there are a number of allocation and reservedQty fields in the PartWhse table. I'm just not sure what you would add and/or subtract to get your available quantity.
Sent: Monday, June 15, 2009 8:17:30 AM
Cheers.
Hi,
Regards,
CHRIS THOMPSON
description, etc.
Cliff Drumeller
IT Manager
408 786 0348
408 314 7420 cell
Of Chris Thompson
Importance: Low
Cheers.
<mailto:sgotschall%40yahoo.com> >
Hi,
Qty
Regards,
CHRIS THOMPSON
Hi Cliff,
description, etc.
Cliff Drumeller
IT Manager
408 786 0348
408 314 7420 cell
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Chris Thompson
Importance: Low
Cheers.
Hi,
Qty
Regards,
CHRIS THOMPSON
Hi,
Cheers,
CHRIS
Hi Cliff,
description, etc.
Cliff Drumeller
IT Manager
408 786 0348
408 314 7420 cell
Of Chris Thompson
Importance: Low
Cheers.
Hi,
Qty
Regards,
CHRIS THOMPSON
This is where the join type comes into play. If the on hand qty is zero - there is no bin
You need an outer join to return results of Part table if there is no PartBin record
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Hi,
> Cheers,
> CHRIS
> From: Chris Thompson <chriselectrix@...>
> Hi Cliff,
> From: Cliff Drumeller <cliff@massprecision .com>
> description, etc.
> Cliff Drumeller
> IT Manager
> 408 786 0348
> 408 314 7420 cell
> Of Chris Thompson
> Importance: Low
> Cheers.
> From: Steven Gotschall <sgotschall@ yahoo. com
> From: Chris Thompson <chriselectrix@ ymail.com>
> Hi,
> Qty
> Regards,
> CHRIS THOMPSON
Superb!!
One last thing.
If I want to display the 'available' qty i.e. the qtyonhand in all bins MINUS the qty allocated to orders (parts that are on unshipped orders).
If you can helo with that, I will be very grateful.
CHEERS.
Sent: Friday, 19 June, 2009 12:00:31
--- In vantage@yahoogroups .com, Chris Thompson <chriselectrix@ ...> wrote:
> Hi,
> Cheers,
> CHRIS
> From: Chris Thompson <chriselectrix@ ...>
> Hi Cliff,
> From: Cliff Drumeller <cliff@massprecisio n .com>
> description, etc.
> Cliff Drumeller
> IT Manager
> 408 786 0348
> 408 314 7420 cell
> Of Chris Thompson
> Importance: Low
> Cheers.
> Hi,
> Qty
> Regards,
> CHRIS THOMPSON
Why not use Part and PartWhse - the PartWhse table holds Qty on hand and all the allocated qtys (at least in V8.03xxx) - look in the data dictionary to see if this would work for you...
One thing to note - sometimes the qtys in this table are not updated properly which requires a 'conversion' routine to be run to recalculate them (6430)
> Superb!!
> One last thing.
> CHEERS.
> From: bw2868bond <bwalker@...>
> > Hi,
> > Cheers,
> > CHRIS
> > Hi Cliff,
> > description, etc.
> > Cliff Drumeller
> > IT Manager
> > 408 786 0348
> > 408 314 7420 cell
> > Of Chris Thompson
> > Importance: Low
> > Cheers.
> > Hi,
> > Qty
> > Regards,
> > CHRIS THOMPSON
I have managed to get the SalesDemandQty to appear, but if a part has two bins assigned, the no. of lines in the BAQ returned is doubled.
For example a Part has two bins A and B, before adding the PartWhse table it shows the onhandqty correctly. As soon as I add the PartWhse table it repeats the two lines.
All that I require is an OnHandQty for all the bins added together, minus the SalesDemandQty to give me my Available qty.
Sent: Friday, 19 June, 2009 12:45:41
Subject: [Vantage] Re: Epicor 9 - BAQ Help
> Superb!!
> One last thing.
> CHEERS.
> From: bw2868bond <bwalker@... >
> > Hi,
> > Cheers,
> > CHRIS
> > Hi Cliff,
> > description, etc.
> > Cliff Drumeller
> > IT Manager
> > 408 786 0348
> > 408 314 7420 cell
> > Of Chris Thompson
> > Importance: Low
> > Cheers.
> > Hi,
> > Qty
> > Regards,
> > CHRIS THOMPSON
I have added my BAQ to a quick search and each time it returns the results, it returns two lines per part. One with an available value and one without.
Any ideas?
> Superb!!
> One last thing.
> CHEERS.
> > Hi,
> > Cheers,
> > CHRIS
> > Hi Cliff,
> > description, etc.
> > Cliff Drumeller
> > IT Manager
> > 408 786 0348
> > 408 314 7420 cell
> > Of Chris Thompson
> > Importance: Low
> > Cheers.
> > Hi,
> > Qty
> > Regards,
> > CHRIS THOMPSON
