8.03.408B - BAQ - Calculated Field
Hi
On 9.04.505C, PartWhse.AllocQty is ALWAYS Zero.
Why is this?
I am trying to write a BAQ which will display any Sales Orders where the
OnHandQty is less than the the required qty of a particular part for an order.
In summary I want a BAQ which will show all open orders wherer they are waiting
for parts being made before they can be shipped/closed.
Any help would be appreciated.
Sent: Tue, 5 October, 2010 15:41:29
Subject: [Vantage] Re: 8.03.408B - BAQ - Calculated Field
Â
Do you need what is available in each bin? If not, you can pull both values from
PartWhse. AllocQty and OnhandQty are both found there.
Definitions:
AllocQty - A summary of the outstanding quantities for order open sales releases
that are being filled from stock and of the open job material requirements that
are to be issued from stock (JobMtl.Buyit = No) for this Part within a specific
warehouse. NOTE: This value is the TOTAL of the allocation demands. Calculated
as the sum of SalesAllocQty + SalesReservedQty + SalesPickingQty +
SalesPickedQty + JobAllocQty + JobReservedQty. Note, JobUnFirmAllocQty is not
included. The system calculates Available as OnhandQty - AllocQty.
OnhandQty - A summary of PartBin.OnHandQty for the warehouse where the bin is a
nettable bin (WhseBin.NonNettable = NO). Maintained via the PartBin write
trigger.
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Oddly I am just emailing support about the same thing.
> If anyone has any ideas it'd be appreciated.
> From: Blake Clemens <blake.clemens@...>
> Sent: Tue, 5 October, 2010 15:27:20
> Subject: [Vantage] 8.03.408B - BAQ - Calculated Field
> ÂÂ
> I'm creating a query that shows the "real" available on hand quantity.
> We were told by support that in order to get the actual on hand qty you
> need to Total up the PartBin.OnHandQty and subtract from that
> PartWhse.AllocQty. I want to do this on a calculated field in a query.
> I've tried many versions of this and none work properly. For example...
> Total (PartBin.OnHandQty - PartWhse.AllocQty) will run but the numbers
> don't add up when we check the qty with Vantage. If I try modifying
> this code I'll get a sytax error... for example... (Total
> (PartBin.OnHandQty)) - PartWhse.AllocQty or ((Total (PartBin.OnHandQty))
> - PartWhse.AllocQty) both of these give me a sytax error. Does anyone
> have any ideas what I may be doing wrong. Any help would be greatly
> appreciated.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> Delmarva Millwork Corporation
> (800) 360-2364 x132
appreciated.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Â
appreciated.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Have you tried
PartQty.OnHandQty-PartQty.DemandQty ?
Sent: Tue, 5 October, 2010 15:28:54
Subject: Re: [Vantage] 8.03.408B - BAQ - Calculated Field
Â
Â
appreciated.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Are you saying there is a PartQty table? I don't see that in my list of available tables.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
Sent: Tuesday, October 05, 2010 10:37 AM
Have you tried
From: Chris Thompson <chriselectrix@... <mailto:chriselectrix%40ymail.com> >
From: Blake Clemens <blake.clemens@... <mailto:blake.clemens%40d-m-c.com> >
appreciated.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Do you need what is available in each bin? If not, you can pull both values from PartWhse. AllocQty and OnhandQty are both found there.
Definitions:
AllocQty - A summary of the outstanding quantities for order open sales releases that are being filled from stock and of the open job material requirements that are to be issued from stock (JobMtl.Buyit = No) for this Part within a specific warehouse. NOTE: This value is the TOTAL of the allocation demands. Calculated as the sum of SalesAllocQty + SalesReservedQty + SalesPickingQty + SalesPickedQty + JobAllocQty + JobReservedQty. Note, JobUnFirmAllocQty is not included. The system calculates Available as OnhandQty - AllocQty.
OnhandQty - A summary of PartBin.OnHandQty for the warehouse where the bin is a nettable bin (WhseBin.NonNettable = NO). Maintained via the PartBin write trigger.
> ÂÂ
> appreciated.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
On hand qty is the field that I was using, but for some reason does not work correctly, very often shows the wrong qty.
I called support and they could not explain why this was not working and they told me that other way that I gave you originally to get total OH.
Maybe it's a data issue not a programming issue? If it's working for others?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mattcald_73
Sent: Tuesday, October 05, 2010 10:41 AM
Definitions:
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Chris Thompson <chriselectrix@...> wrote:
> Â
> appreciated.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
There is in E9 - not sure about your version
Sent: Tue, 5 October, 2010 15:41:13
Subject: RE: [Vantage] 8.03.408B - BAQ - Calculated Field
Â
available tables.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Chris Thompson
Have you tried
appreciated.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
We have used an OnHandQty field before which also gave the wrong figure when
compared to the onhandqty that you can see throughout Epicor. 90% were right but
the odd one was wrong.
Sent: Tue, 5 October, 2010 16:10:58
Subject: RE: [Vantage] Re: 8.03.408B - BAQ - Calculated Field
Â
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
mattcald_73
Definitions:
trigger.
> Â
> appreciated.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
I've never seen OH off (but that certainly doesn't mean it can't happen).
Allocations can slowly get trashed over time & there is a utility you can routinely run (weekly or even monthly probably OK) to clean things up.
If same exists for some OH problem, appreciate a heads up (thx).
Rob
--- Original Message ---
Sent:Tue 10/5/10 11:34 am
To:vantage@yahoogroups.com
Subj:Re: [Vantage] Re: 8.03.408B - BAQ - Calculated Field
Â
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
mattcald_73
Definitions:
trigger.
> Â
What is the name of this utility?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of robertb_versa@...
Sent: Tuesday, October 05, 2010 12:08 PM
Subject: Re: [Vantage] Re: 8.03.408B - BAQ - Calculated Field
Rob
From:"Chris Thompson" <chriselectrix@... <mailto:chriselectrix%40ymail.com> >
To:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of
mattcald_73
Definitions:
trigger.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , Chris
> To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Â
Good Day:
Please see attached.
Is an Inventory report - BAQ
len.hartka@...
Of Chris Thompson
Sent: Tuesday, October 05, 2010 11:33 AM
available tables.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf Of
Chris Thompson
Have you tried
<mailto:chriselectrix%40ymail.com> <mailto:chriselectrix%40ymail.com>
<mailto:blake.clemens%40d-m-c.com> <mailto:blake.clemens%40d-m-c.com>
appreciated.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Nothing attached. Can you email me directly... blake.clemens@...
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Len Hartka
Sent: Tuesday, October 05, 2010 12:28 PM
Cc: IT Department
Good Day:
len.hartka@... <mailto:len.hartka%40sunautomation.com>
Behalf
Of Chris Thompson
available tables.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf Of
Chris Thompson
Have you tried
appreciated.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Good Day Blake:
Sorry, I forgot this list strip attachments.
Imbedded in email, but on second thought, I
do not think it is what you are after.
I thought you could just not find
the QOH.
len.hartka@... <mailto:len.hartka@...>
Of Blake Clemens
Sent: Tuesday, October 05, 2010 12:35 PM
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Cc: IT Department
Good Day:
Behalf
Of Chris Thompson
available tables.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf Of
Chris Thompson
Have you tried
appreciated.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Wish I could from memory (but can't tomorrow as I'm having spinal fusion surgery so it may be a while until I can confirm.)
My understanding is that it is a routinely used utitlity so perhaps someone out there can share (???n).
Rob
Sent:Tue 10/5/10 12:14 pm
To:<vantage@yahoogroups.com>
Subj:RE: [Vantage] Re: 8.03.408B - BAQ - Calculated Field
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Rob
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
mattcald_73
Definitions:
Support's job is to to lead you to the allocations recalc/correction utility (particularly for a known problem like this that cropped up YEARS ago.)
I'd give them a call.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Rob
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
mattcald_73
Definitions:
Good Day:
OK, I give up.
They strip out images pasted into the email also.
The only thing I was adding was that we use PartWhse:OnHandQty;
but on second look you already had that I think.
len.hartka@...
Of Len Hartka
Sent: Tuesday, October 05, 2010 3:10 PM
Good Day Blake:
the QOH.
<mailto:len.hartka%40sunautomation.com> >
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Len Hartka
Cc: IT Department
Good Day:
Behalf
Of Chris Thompson
available tables.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf Of
Chris Thompson
Have you tried
appreciated.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Someone mentioned on here that there should be some kind of utility provided by support that fixes the PartWhse.OnHandQty. Does anyone have the name of this utility? I just spoke to support and they were not aware of anything.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Definitions:
> Â
> appreciated.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Conversion programs 5030 and 6430 cleans this up. Run the Vantage Admin Tool, logon as a System Manager user, and click on Database Conversions.
These are just various Progress Programs that are designed to deal with various database issues. It manipulates the Vantage database directly.
-bws
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Blake Clemens
Sent: Tuesday, October 19, 2010 4:06 PM
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Definitions:
> Â
> appreciated.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
I think what you want is conversion program 6430 which you run from the Admin
Tools on your server. This just adjusts the quantities at an instance in time.Â
You need to run it regularly to keep them in balance. I wish Epicor would fix
the problem once and for all.
Sent: Tue, October 19, 2010 4:05:46 PM
Â
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
mattcald_73
Definitions:
trigger.
> Â
> appreciated.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
