I want to be able to open the new outlook mail form when a user clicks the update button on the Task Management section on the Case (HelpDesk) form.
I believe I need to use the getnativecontrolreference with the GUID of the epiUpdateTask button (I think that is the correct name as I doing this for memory).
But what next? Create a sub routine for the click event and then include my code. I've actually tried that and whilst I get no compilation errors nothing actually happens when I click the button. I have setup a messagebox to fire for testing.
I have all of the other email functionality working in this form and it is the last piece.
So I guess the real question is....How do you access events for objects that already exist on a form that you are customizing and you don't have the SDK? Is there some other way that I am missing like running .NET code from a BPM perhaps. I had considered just using a global alert on the task, but the alert is read only and is setup to send to the salesperson, which is not who I need it to go to.
I'm hoping there is a quick and easy answer to this, as I could trawl the web for a long time trying to work it out. We are on 9.05701.
Any assistance appreciated.
Simon Hall
btn = (Button)csm,.GetNativeControlReference("GUID");
btn.Click -= new System.EventHandler(btn_Click);
Your event function
On Wed, Nov 27, 2013 at 8:15 AM, <s1mhall@...> wrote:Â<div> <p>Hi everyone,<br>I want to be able to open the new outlook mail form when a user clicks the update button on the Task Management section on the Case (HelpDesk) form.<br><br>I believe I need to use the getnativecontrolreference with the GUID of the epiUpdateTask button (I think that is the correct name as I doing this for memory). <br>
So I guess the real question is…How do you access events for objects that already exist on a form that you are customizing and you don't have the SDK? Is there some other way that I am missing like running .NET code from a BPM perhaps. I had considered just using a global alert on the task, but the alert is read only and is setup to send to the salesperson, which is not who I need it to go to.
Simon Hall</div> <div style="color:rgb(255,255,255);min-height:0px;"></div>
Thanks Jose,
I'll give it a go.....Just of to work now in the trusty Kombi
Cheers
Simon Hall
---In vantage@yahoogroups.com, <jose@...> wrote:You need to use csm.GetNativeControlRef("GUID"); as you mentioned then with the button you just got a hold of simply register an interest in the on Click event and in that event execute your code. Once thing I will warn you about is that if the button is already there it probably does something and you may be stepping on it by registering your own event.InitCustomCode()btn = (Button)csm,.GetNativeControlReference("GUID");
btn.Click += new System.EventHandler(btn_Click);DisposeCustomCode()btn.Click -= new System.EventHandler(btn_Click);
Your event function
private void btn_Click(object sender, EventArgs e){}
On Wed, Nov 27, 2013 at 8:15 AM, <s1mhall@...> wrote:<div> <p>Hi everyone,<br>I want to be able to open the new outlook mail form when a user clicks the update button on the Task Management section on the Case (HelpDesk) form.<br><br>I believe I need to use the getnativecontrolreference with the GUID of the epiUpdateTask button (I think that is the correct name as I doing this for memory). <br>
Thanks Jose,
Cheers
Simon Hall
You need to use csm.GetNativeControlRef("GUID"); as you mentioned then with the button you just got a hold of simply register an interest in the on Click event and in that event execute your code. Once thing I will warn you about is that if the button is already there it probably does something and you may be s tepping on it by registering your own event.
InitCustomCode()btn = (Button)csm,.GetNativeControlReference("GUID");btn.Click += new System.EventHandler(btn_Click);
Your event functionprivate void btn_Click(object sender, EventArgs e){
Hi everyone,
Simon Hall
