Calculation of remaining hours in Scheduling board
Thank you all for shining some light on this issue!
The moment I replaced "burden hours" with "productive hours"
it was clear to me!
Because we schedule/use persons and machines as separate entities.
"machine hours" were confusing.
It makes sense that persons have more productive hours (burden) than
laborhours depending on their function in a workshop.
The remark "crew size=1" is appliable to our situation and we use
this.
The only thing i had to do is to equal burden to labor and it al
comes together.
--- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@...>
wrote:
> It's the same with the labor on the Production Detail Report. The
> labor estimates and actuals (from JobOper) are based on burden
> (machine) hours. It makes sense scheduling would look at burden
hours
> instead of labor hours. The focus is on the contrained resources
> (machines) and the labor is calculated to whatever is required to
> operate those machines.
> You need to have a resource setup as the primary operation detail in
> each Operation setup and not just a resource group. It needs the
> resource so that it can calculate the burden (machine) time. If
there
> is no machine, it won't calculate the actual burden hours properly.
> If I understand your situation correctly, you need the burden hours
to
> directly correspond with labor hours. Consider checking
the "burden =
> labor" box and set Crew Size=1 in the Resource Group/Resource setup
so
> the burden hours will calculate one for one with labor hours. This
> way your actual burden hours should match up with your
EstProdHours.
> And since your burden is included in labor rate, set the burden rate
> to zero and your costs should come out okay as well.
> --- In vantage@yahoogroups.com, "fonsvanderbeek" <fons.vanderbeek@>
> wrote:
> > Vantage 8.03 Progress database
> > We have setup our installation in a way that every hour that is
spent
> > on a project is entered in "laborhours", we don't
use "burdenhours"
> > and leave this field empty (zero) but now we encounter problems
in
> > the Job scheduling board. It seems that only burdenhours are
taken
> > into account for calculating the remaining hours.
> > I don't get it: When I look at the Details in "The job scheduling
> > board"
> > on the left there is a field "Est Hours", on the right there is a
> > field "Remaining hours"
> > The Field "Est Hours" contains the total of the estimated hours
based
> > on LABORHOURS
> > BUT
> > The Field "Remaining hours" depends on entry based on BURDEN
hours
> > ("Est Hours" minus the total of all burdenhours), but we dont
> > use "Burden Hours"...........
> > The load relieve is based on Hours
> > (company maintenance->company->company configuration->modules ->
> > production -> job -> load relieved by hours)
> > We dont use "labor=burden" setting because it seemed unlogical to
> > fill a database with identical entries. We planned to use "burden
> > hours" for overtime in future
> > My questions are:
> > Do we have to use "Burden Hours"?
> > What is the exact definition and use of "Burden hours"? VS "Labor
> > Hours"?
> > Does a setting exist that is needed for a different calculation
> > of "Remaining Hours"?
We have setup our installation in a way that every hour that is spent
on a project is entered in "laborhours", we don't use "burdenhours"
and leave this field empty (zero) but now we encounter problems in
the Job scheduling board. It seems that only burdenhours are taken
board"
The Field "Est Hours" contains the total of the estimated hours based
on LABORHOURS
BUT
The Field "Remaining hours" depends on entry based on BURDEN hours
My questions are:
Hours"?
The way I understand the system to work, Labor Hours are hours an
employee spends on a job, Burden hours are the hours the machine spends
on the job. Often, Burden hours will be equal to labor hours. We also
have cases where an employee runs 2 machines for a day, so each job
accumulates 1/2 the day of labor hours/costs and a full day of burden
hours/costs. Burden hours would only be 0 if an employee is on an
indirect operation. I believe hours are estimated by total number of
production hours needed, so it makes sense that they would get relieved
by burden hours since those are the actual production hours applied to
the job.
Are you using data collection? I'm just wondering how you are setting
burden hours = 0 on every transaction. I thought by default for hours
put on jobs it would at least equal the labor hours applied?
Of fonsvanderbeek
Sent: Tuesday, August 07, 2007 3:31 PM
Subject: [Vantage] Calculation of remaining hours in Scheduling board
board"
on LABORHOURS
BUT
My questions are:
Hours"?
Yahoo! Groups Links
<DIV><font size="1.5" face="Bookman Old Style">__________________________________________________________________________________________________________________
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
__________________________________________________________________________________________________________________<DIV><FONT>
We manual set the burden hours to zero and yes, we were also told
that burden hours can be used as machine hours, but we have a number
of machines which run unattended, therefor we treat a machine as a
jobemployee by using just one field entry "labor", entry of hours is
straight forward.
futhermore by using "labor hours" job overview and calculation made
most sense.
spends
also
burden
of
relieved
to
> the job.
setting
hours
Behalf
> Of fonsvanderbeek
board
spent
> board"
based
> on LABORHOURS
> BUT
> My questions are:
> Hours"?
must
access. )
Builder
> Yahoo! Groups Links
all copies.
Then it sounds like for it to work you will need to use the fields as
they were intended and burden hours will need to be used to accumulate
job hours and relieve load.
Of fonsvanderbeek
Sent: Tuesday, August 07, 2007 3:57 PM
Subject: [Vantage] Re: Calculation of remaining hours in Scheduling
board
straight forward.
most sense.
spends
also
burden
of
relieved
to
> the job.
setting
hours
Behalf
> Of fonsvanderbeek
board
spent
> board"
based
> on LABORHOURS
> BUT
> My questions are:
> Hours"?
must
access. )
Builder
> Yahoo! Groups Links
all copies.
Yahoo! Groups Links
I agree with you, this would be pragmatic but........
it stil puzzles me why in the scheduling board one field is based
on the expected laborhours (estimated hours) and the counterpart
(remaining hours) is based on burdenhours.......
The estimated hours is purely based on labor, not on burden...
Did somebody notice this also?
as
accumulate
Behalf
> Of fonsvanderbeek
> board
number
is
> straight forward.
> most sense.
> spends
> also
job
> burden
number
> of
> relieved
applied
> to
> > the job.
> setting
> hours
> Behalf
> > Of fonsvanderbeek
> board
> spent
use "burdenhours"
in
taken
> > board"
> based
> > on LABORHOURS
> > BUT
hours
> > My questions are:
> > Hours"?
> must
> access. )
> Builder
> > Yahoo! Groups Links
you
delete
> all copies.
must
access. )
Builder
> Yahoo! Groups Links
Yes. We include burden in our labor rate; hence, we set burden rate
to zero. Side note: Go look at the project tracker, more tab,
summary, project. Do you find anything funny looking with labor,
burden hours, and total hours?
fields
> as
> accumulate
On
> Behalf
> > Of fonsvanderbeek
Scheduling
> > board
told
> number
a
hours
> is
> > straight forward.
made
> > most sense.
an
machine
> > spends
We
> > also
each
> job
> > burden
an
> number
> > of
> > relieved
> applied
> > to
> > > the job.
> > setting
for
> > hours
On
> > Behalf
> > > Of fonsvanderbeek
Scheduling
> > board
is
> > spent
> use "burdenhours"
problems
> in
> taken
scheduling
> > > board"
is a
hours
> > based
> > > on LABORHOURS
> > > BUT
> hours
to
use "burden
> > > My questions are:
VS "Labor
> > > Hours"?
calculation
You
> > must
> > access. )
> > Builder
goto:
> > > Yahoo! Groups Links
_
privileged
> you
> delete
> > all copies.
_
You
> must
> access. )
> Builder
> > Yahoo! Groups Links
If you split labor (employee running 2 machines) you would want 1/2 the
employee labor charged to the job yet the job schedule relieved by the
full shift (burden hours).
Patrick J. Winter
Of mustardbuzzards
Sent: Tuesday, August 07, 2007 3:59 PM
Subject: [SPAM] [Vantage] Re: Calculation of remaining hours in
Scheduling board
"fonsvanderbeek"
fields
> as
> accumulate
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]
On
> Behalf
> > Of fonsvanderbeek
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Scheduling
> > board
told
> number
a
hours
> is
> > straight forward.
made
> > most sense.
an
machine
> > spends
We
> > also
each
> job
> > burden
an
> number
> > of
> > relieved
> applied
> > to
> > > the job.
> > setting
for
> > hours
On
> > Behalf
> > > Of fonsvanderbeek
Scheduling
> > board
is
> > spent
> use "burdenhours"
problems
> in
> taken
scheduling
> > > board"
is a
hours
> > based
> > > on LABORHOURS
> > > BUT
> hours
to
use "burden
> > > My questions are:
VS "Labor
> > > Hours"?
calculation
You
> > must
> > access. )
> > Builder
goto:
> > > Yahoo! Groups Links
_
privileged
> you
> delete
> > all copies.
_
You
> must
> access. )
> Builder
> > Yahoo! Groups Links
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
The estimated is not based on labor hours, at least not here, it is
based on machine hours (Production hours) which is equivalent to burden
hours.
Of fonsvanderbeek
Sent: Tuesday, August 07, 2007 4:51 PM
board
as
accumulate
Behalf
> Of fonsvanderbeek
> board
number
is
> straight forward.
> most sense.
> spends
> also
job
> burden
number
> of
> relieved
applied
> to
> > the job.
> setting
> hours
> Behalf
> > Of fonsvanderbeek
> board
> spent
use "burdenhours"
in
taken
> > board"
> based
> > on LABORHOURS
> > BUT
hours
> > My questions are:
> > Hours"?
> must
> access. )
> Builder
> > Yahoo! Groups Links
you
delete
> all copies.
must
access. )
Builder
> Yahoo! Groups Links
Yahoo! Groups Links
Yes you are right
The total of burden is the same as the total of labor but actual burden = 0
This is as expected because we always set burdenhours to zero
Let me put it this way:
"Burden hours are production hours made by machine or human"
The actual costs are based on laborrate*laborhours + burdenrate*burdenhours
if burdenrate = zero
costs of production (e.g. maintenance costs/ rental of machines) should
be included in the overall laborrate of that specific department
If the laborrate is based on deparment.........
> fields
>> as
>> accumulate
> On
>> Behalf
>>> Of fonsvanderbeek
> Scheduling
>>> board
> told
>> number
> a
> hours
>> is
>>> straight forward.
> made
>>> most sense.
> an
> machine
>>> spends
> We
>>> also
> each
>> job
>>> burden
> an
>> number
>>> of
>>> relieved
>> applied
>>> to
>>>> the job.
>>> setting
> for
>>> hours
> On
>>> Behalf
>>>> Of fonsvanderbeek
> Scheduling
>>> board
> is
>>> spent
>> use "burdenhours"
> problems
>> in
>> taken
> scheduling
>>>> board"
> is a
> hours
>>> based
>>>> on LABORHOURS
>>>> BUT
>> hours
> to
> use "burden
>>>> My questions are:
> VS "Labor
>>>> Hours"?
> calculation
> You
>>> must
>>> access. )
>>> Builder
> goto:
>>>> Yahoo! Groups Links
> _
> privileged
>> you
>> delete
>>> all copies.
> _
> You
>> must
>> access. )
>> Builder
>>> Yahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups Links
You are right... it's clear now
> Patrick J. Winter
> Of mustardbuzzards
> Scheduling board
> "fonsvanderbeek"
> fields
>> as
>> accumulate
> On
>> Behalf
>>> Of fonsvanderbeek
> Scheduling
>>> board
> told
>> number
> a
> hours
>> is
>>> straight forward.
> made
>>> most sense.
> an
> machine
>>> spends
> We
>>> also
> each
>> job
>>> burden
> an
>> number
>>> of
>>> relieved
>> applied
>>> to
>>>> the job.
>>> setting
> for
>>> hours
> On
>>> Behalf
>>>> Of fonsvanderbeek
> Scheduling
>>> board
> is
>>> spent
>> use "burdenhours"
> problems
>> in
>> taken
> scheduling
>>>> board"
> is a
> hours
>>> based
>>>> on LABORHOURS
>>>> BUT
>> hours
> to
> use "burden
>>>> My questions are:
> VS "Labor
>>>> Hours"?
> calculation
> You
>>> must
>>> access. )
>>> Builder
> goto:
>>>> Yahoo! Groups Links
> _
> privileged
>> you
>> delete
>>> all copies.
> _
> You
>> must
>> access. )
>> Builder
>>> Yahoo! Groups Links
> Yahoo! Groups Links
(machine) hours. It makes sense scheduling would look at burden hours
resource so that it can calculate the burden (machine) time. If there
If I understand your situation correctly, you need the burden hours to
directly correspond with labor hours. Consider checking the "burden =
labor" box and set Crew Size=1 in the Resource Group/Resource setup so
way your actual burden hours should match up with your EstProdHours.
--- In vantage@yahoogroups.com, "fonsvanderbeek" <fons.vanderbeek@...>
> board"
> on LABORHOURS
> BUT
> My questions are:
> Hours"?
