8.03.404 - Job information
Actual Labor comes from Shop Employee.
Actual Burden comes from Operation rates configured relationship
between labor and Burden.
Forget to End activity and labor and burden costs continue to accrue.
IF you use setup there are different rates for this and direct types
must be sure to clock into setup on operation.
You must watch closely your units of measure for estimates and qty's
per. If on 8.o you must run build shop load.
If actual labor goes over, there is no load left
--- In vantage@yahoogroups.com, "c.chest" <c.chest@...> wrote:
> We are still getting discrepant data as far as labor, burden and
> load. How is Vantage calculating these. I don't really understand
> where each is coming from in the first place. If we have resources
> marked as labor equals burden, when a job is released, they don't
> always show up on the schedule with the same amount of time.
> --- In vantage@yahoogroups.com, Todd Caughey <caugheyt@> wrote:
> > End Activity just closes the Labor Detail record for the type of
> labor (Direct, Setup, Indirect) but the employee...until Clocked
> Out....is still "earning" payroll hours....or Idle time. This would
> have to be adjusted with Labor Edit.
> > -Todd C.
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf Of c.chest
> > Sent: Monday, December 08, 2008 1:54 PM
> > Subject: [Vantage] 8.03.404 - Job information
> > Can someone please explain how Vantage calculates the labor
> transaction
> > information against a job:
> > Labor Hrs
> > Burden Hrs
> > Load
> > We created and use machine employees to clock into jobs instead of
> an
> > actual employee ID. If the machine employee doesn't get "clocked"
> out
> > of Vantage, but the end activity was done, the Burden continues to
> pick
> > up the hours not being clocked out. Is this normal?
> > Thanks
> > cindy
Can someone please explain how Vantage calculates the labor transaction
Labor Hrs
Burden Hrs
Load
We created and use machine employees to clock into jobs instead of an
actual employee ID. If the machine employee doesn't get "clocked" out
of Vantage, but the end activity was done, the Burden continues to pick
cindy
End Activity just closes the Labor Detail record for the type of labor (Direct, Setup, Indirect) but the employee...until Clocked Out....is still "earning" payroll hours....or Idle time. This would have to be adjusted with Labor Edit.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of c.chest
Labor Hrs
Burden Hrs
Load
cindy
> -Todd C.
Behalf Of c.chest
transaction
> Labor Hrs
> Burden Hrs
> Load
an
out
pick
> Thanks
> cindy
There is a "Job Costing: Technical Reference Guide" that you can download
from the EpicWeb. This may help understand the logic on how the labor is
calculated
Scott L
c.chest
Sent: Tuesday, December 09, 2008 7:18 AM
Subject: [Vantage] Re: 8.03.404 - Job information
> -Todd C.
Behalf Of c.chest
transaction
> Labor Hrs
> Burden Hrs
> Load
an
out
pick
> Thanks
> cindy
