Call Crystal Reports from menu w/o BAQ Report Designer
Hi Brian,
I have 8.03.407 and I haven’t had any problems. I downloaded the Logicity viewer a while back, but then I got busy and never got around to checking it out. Maybe someday I’ll get some free time to take a look.
Linda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Brian W. Spolarich
Sent: Thursday, October 07, 2010 10:06 AM
Subject: RE: [Vantage] Call Crystal Reports from menu w/o BAQ Report Designer
I ran into problems with this approach. Specifically, the Crystal
Runtime that 8.03.405 had (and I'm fairly certain it hasn't changed
since) had problems with subreports at times.
I wound up calling an external program and using the Logicity CR
viewer to display my direct-to-database reports.
-bws
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of Linda Lowney
Sent: Thursday, October 07, 2010 8:26 AM
Designer
Hi John,
Add a new menu item. Select Custom Report Link for Program Type.
Regards,
Linda
Of wapnerj
Sent: Wednesday, October 06, 2010 4:59 PM
Subject: [Vantage] Call Crystal Reports from menu w/o BAQ Report
Designer
Is there a way to invoke the Crystal Runtime with a .RPT name as a
parameter from the Vantage 8 menu?
I want to run a simple ODBC-based Crystal Report without all of the BAQ
overhead.
Thanks in advance,
John Wapner
Bracalente Mfg.
http://groups.yahoo.com/group/vantage/files/. <http://groups.yahoo.com/group/vantage/files/>
Is there a way to invoke the Crystal Runtime with a .RPT name as a parameter from the Vantage 8 menu?
I want to run a simple ODBC-based Crystal Report without all of the BAQ overhead.
Thanks in advance,
John Wapner
Bracalente Mfg.
Hi John,
Regards,
Linda
Of wapnerj
Designer
overhead.
Thanks in advance,
John Wapner
Bracalente Mfg.
-bws
Of Linda Lowney
Designer
Hi John,
Regards,
Linda
Of wapnerj
Designer
overhead.
Thanks in advance,
John Wapner
Bracalente Mfg.
