Custom Crystal Report in V8.03.407
Brian, can I ask how you use the Logicity viewer for Vantage reports
instead of Crystal? The Crystal viewer is integrated with Vantage -
I don't know if I could get my users to use an alternate if it
require extra steps.
Bill
--- In vantage@yahoogroups.com, "Brian W. Spolarich "
<bspolarich@...> wrote:
> I have had similar issues with Custom Crystal Reports in
Vantage. The
> CR viewer in Vantage doesn't handle subreports very well, and
you'll get
> different results in the Vantage CR runtime than you will in the
Crystal
> runtime.
> I gave up and use the Logicity viewer instead. I suppose if I
were a
> better citizen I will tell Epicor but my relationship with Tech
Support
> is a somewhat frustrated one.
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced
Photonix /
> Picometrix
> bspolarich@... ~ 734-864-5618 ~
> www.advancedphotonix.com
Behalf
> Of peterlv2002
> Sent: Thursday, January 15, 2009 11:00 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Custom Crystal Report in V8.03.407
> Has anyone had any issues running custom crystal reports that have
> prompts through the Vantage\crystal runtime? I have several reports
> I have written that have prompts (parameters). They ran fine until
> the must recent patch. They will work with the developer edition of
> crystal, cview (crystal's stand alone viewer), but not in Vantage.
> Epicor tells me to re write them. I did and still do not run through
> vantage. Epicor also suggested a BAQ report, but i have relationship
> issue that the BAQ tool does not seem to accommodate. I need to
> relate invchead to the salesrep table to get the reps name. But the
> repcodes in invchead are in an array which the BAQ report to tools
has
> not way to relate to.
repcodes in invchead are in an array which the BAQ report to tools has
What version did you upgrade from?
~Charlie
________________________________________
peterlv2002
You have to save the report with no data check box unchecked in the report
to get the prompts to come up in the run time.
Steve
Sent: January 15, 2009 10:00 AM
8.03.403d. The support expert says some data may changed. I
thought the only time the table definitions changed was with a schema
change, which would have been when the patch went form 8.03.4xx to
8.03.5xx
There is a known issue with prompts but I don't think this is your problem
look at the post just before you made this one I think that person may be
right.
~Charlie
_____
peterlv2002
Sent: Thursday, January 15, 2009 11:08 AM
Subject: [Vantage] Re: Custom Crystal Report in V8.03.407
8.03.5xx
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.176 / Virus Database: 270.10.7/1893 - Release Date: 1/15/2009
7:46 AM
Thanks for your the thought, been there , done that.
Are you getting an activeX error messages on reports that have prompts?
~Charlie
peterlv2002
Sent: Thursday, January 15, 2009 11:10 AM
I have had similar issues with Custom Crystal Reports in Vantage. The
CR viewer in Vantage doesn't handle subreports very well, and you'll get
different results in the Vantage CR runtime than you will in the Crystal
runtime.
I gave up and use the Logicity viewer instead. I suppose if I were a
better citizen I will tell Epicor but my relationship with Tech Support
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
Of peterlv2002
There is not much support from vantage on these issue and you can not get to
the knowledge base now the SAP has purchased Business objects. One thing
that I have found that fixes some of the problems is modify the report to
remove the printer (No printer Optimized for screen display).
Steve
Sent: January 15, 2009 10:24 AM
Subject: RE: [Vantage] Custom Crystal Report in V8.03.407
runtime.
-bws
Picometrix
Of peterlv2002
You may want to try un-installing all crystal runtime versions, and
then install only the latest version and see if that helps.
Adam Whipp
