Perfect answer J. Thanks so much Jose….
Mike…
Sent: Tuesday, February 10, 2015 9:21 AM
To: Vantage
Subject: Re: [Vantage] Re: Can't access menu maintenance - getting path access error - Epicor 9.05.700
Nah it won't the reason for this is because that Menu.dll uses an XML file, every other menu in epicor doesn't need an extra file
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Tue, Feb 10, 2015 at 10:07 AM, Mike Abell mabell@... [vantage] <vantage@yahoogroups.com> wrote:
I guess I was worried that it might crop up on other menus trying to be accessed. But I’ll make sure and do the “run as administrator†on new installs from now on and see if I have any problem. Thanks a bunch!
Mike..
Sent: Tuesday, February 10, 2015 9:04 AM
To: Vantage
It should be fine, I've seen it happen from time to time, but most users don't need access to menu maintenance
On Tue, Feb 10, 2015 at 10:02 AM, Anthony Gercar agercar@... [vantage] <vantage@yahoogroups.com> wrote:
Its not really a bug…More of a windows permission issue…
Sent: Tuesday, February 10, 2015 9:58 AM
Subject: RE: [Vantage] Re: Can't access menu maintenance - getting path access error - Epicor 9.05.700
Thanks Jose, that fixed it. I’m worried now that it might happen on other clients during our testing. Is this a known bug?
Mike…
Sent: Tuesday, February 10, 2015 8:56 AM
To: Vantage
That's just an error for your local client, go to that location and give yourself (or everyone) access to that folder.
On Tue, Feb 10, 2015 at 9:53 AM, jockthemotie@... [vantage] <vantage@yahoogroups.com> wrote:
Hi,
You need to run Epicor client as an Administrator, then you should be all set.
