Accessing menu maintenance
I have seen that also.
It start happening when I switched from Windows XP client to Windows 7.
I set Epicor client to always run as administrator:
Right Click Production Epicor shortcut, Click on Properties, Go to Compatibility tab. Under Privilege level check Run this program as an administrator.
Regards,
Mikhail Melnik
--- In vantage@yahoogroups.com, <brye@...> wrote:
Thanks everyone! I thought that was the case but have never seen this
error. I wasn't getting it when we were on 9.05.701 and I don't think my
permission have changed since then. I have sent a message to the IT
department to resolve it.
Bethany Rye
Epicor Business Analyst
I'm hoping someone can shed some light on this. We just moved up to
9.05.702A and I was trying to access Menu Maintenance. I have Security
Admin rights. When I click on the menu option to open it, I get the
following error message:
Access to the path 'C:\Program Files\Epicor
Software\Epicor905\Client\res\WebAccess.xml' is denied.
I've never seen this before. What would that file have to do with menu
maintenance anyway?
Bethany Rye
PTI Epicor Business Analyst
Hi Bethany,
Go to the client folder located on your system for the Epicor
installation (c:\program files\epicor....). Right-click in that folder
and give yourself modify access to the folder. This will provide you
with the ability to access menu maintenance.
Regards,
Sigfredo.
Of Bethany Rye
Sent: Tuesday, August 20, 2013 5:12 PM
Subject: [Vantage] Accessing menu maintenance
maintenance anyway?
Bethany Rye
Is this on every client?
Bethany Rye
maintenance anyway?
Bethany Rye
I have not seen this happen on every client and have only seen this
issue just with menu maintenance. Since not everyone will use menu
maintenance, you may only need to do this on those systems and only for
those people who will use menu maintenance if the issue occurs.
However, I have not seen this occur on every client.
Regards,
Sigfredo.
Of Vic Drecchio
Sent: Tuesday, August 20, 2013 5:13 PM
Subject: RE: [Vantage] Accessing menu maintenance
Behalf Of
Bethany Rye
maintenance anyway?
Bethany Rye
Y
ou need read/write to the client folder in the machine.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
> Regards,
> Sigfredo.
> Of Vic Drecchio
> Behalf Of
> Bethany Rye
> maintenance anyway?
> Bethany Rye
NTFS Permissions on the client folder of the computer you are working on.
Set them to Everyone as Full Control.
Bethany Rye
maintenance anyway?
Bethany Rye
Bethany Rye
