Wow…crazy, that worked like a charm, they should note in the documentation it works for migrations to 10.0.700.4. Thanks a bunch my friend!
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Thursday, May 28, 2015 3:04 PM
To: Vantage
Subject: Re: [Vantage] E10 menu maintenance
Rob that was a bug with the security table Run the tables patch
https://epicweb.epicor.com/Support/EpicorERP/Downloads/Epicor%20ERP%20100/TablesPatch_Zip_Installation.pdf.aspx
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/>
Rob Bucek
FAX: (715)284-4084
To: Vantage
Jose C Gomez
Software Engineer
On Thu, May 28, 2015 at 3:50 PM, Rob Bucek rbucek@...<mailto:rbucek@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
10.0.700.4
After migration has anyone not been able to access the Menu Maintenance Form? Getting an error, logged a support call, but just thought I'd ping the group as well.
Application Error
Error Detail
Message: Cannot access this menu item: Menu Maintenance
Inner Exception Message: Record not found.
Program:
Method:
Inner Exception
Record not found.
Inner Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Ice.Proxy.BO.SecurityImpl.GetByIDEx(String pcSecCode)
at Ice.Adapters.SecurityAdapter.GetByIDEx(String pcSecCode)
at Ice.UI.App.MenuMEntry.Transaction.findSecCode()
at Ice.UI.App.MenuMEntry.Transaction.MenuView_EpiRowChanged(EpiRowChangedArgs args)
at Ice.Lib.Framework.EpiDataView.onRowChanged(Int32 CurrentRow, Int32 LastRow)
at Ice.Lib.Framework.EpiDataView.set_Row(Int32 value)
at Ice.UI.App.MenuMEntry.Transaction.findTopMenu()
at Ice.UI.App.MenuMEntry.Transaction.TransactionLoad()
at Ice.Lib.Framework.EpiTransaction.createTransaction()
at Ice.Lib.Framework.EpiTransaction..ctor(Object Sender)
at Ice.Lib.Framework.EpiMultiViewTransaction..ctor(Object Sender)
at Ice.UI.App.MenuMEntry.Transaction..ctor(Object Sender)
at Ice.Lib.App.Launch.InitializeLaunch()
at Ice.Lib.Framework.EpiBaseLaunch.lShow(Object args, DataSet dsMenuItem)
at Ice.Lib.Framework.FormFunctions.Launch(Session session, DataRow menuRow, Object lfo)
at Ice.Lib.Startup.LaunchUIApp(MenuRow menuRow, Session session, Form& form, Object lfo)
Rob Bucek
PH: (715) 284-5376 ext 311<tel:%28715%29%20284-5376%20ext%20311>
Mobile: (715)896-3119<tel:%28715%29896-3119>
FAX: (715)284-4084<tel:%28715%29284-4084>
[cid:1.234354861@...<mailto:cid%3A1.234354861@...>]<http://www.dsmfg.com/>
