Can't close a job Vantage 6.1
Thanks for the help, it had to do with the rates and quantities set
ridiculously low.
Jerry
_____
Sent: Tuesday, January 15, 2008 8:01 AM
Subject: RE: [Vantage] Can't close a job Vantage 6.1
Yes, I have seen this before. One time, on advice from Epicor, we left it
trying to close all weekend.....and the BI file consumed the disk drive and
corrupted the DB. Fortunately a repair fixed things up.
The cause (for us, your case may be different) was a bad pieces per hour
conversion factor on a production rate. It was backwards and caused the
standard hours to be in the millions....causing some sort of weird virtually
endless loop. I don't recall exactly the solution other than it had
something to do with getting the rate fixed. I think I had posted something
about it so I will look in my group archives when I get a chance.
-Todd C.
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of kapokia
Sent: Friday, January 11, 2008 5:48 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] Can't close a job Vantage 6.1
I've a couple of instance where it would take hours to close a job.
This particular one though just hangs up and all you'll see is greyed
out boxes.
Has anybody experienced anything similiar?
Jerry
Yes, I have seen this before. One time, on advice from Epicor, we left it trying to close all weekend.....and the BI file consumed the disk drive and corrupted the DB. Fortunately a repair fixed things up.
The cause (for us, your case may be different) was a bad pieces per hour conversion factor on a production rate. It was backwards and caused the standard hours to be in the millions....causing some sort of weird virtually endless loop. I don't recall exactly the solution other than it had something to do with getting the rate fixed. I think I had posted something about it so I will look in my group archives when I get a chance.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of kapokia
out boxes.
Jerry
