Yes, if I do a trace when manually adding a new record, it does do a
Customer.GetNewCustUPSEmail method call to I assume populate the UI
with blank defaults before later doing an Customer.Update when the
save button it pressed.
If I call the Webservice Customer.GetNewCustUPSEmail, it returns
blank defaults with <UPSQVSeq>5</UPSQVSeq> and <RowMod>A</RowMod>
But passing in a 5 instead of a 0 for the UPSQVSeq with an A for
RowMod to the Webservice Customer.Update still does not insert the
record. (even after doing the GetNewCustUPSEmail webservice call)
Any ideas?
Any ideas?
--- In vantage@yahoogroups.com, "Karen Schoenung" <kschoenung@...> wrote:
> Hi,
> Did you use the trace option in Vantage (when manually adding a new
> record)? Usually for a new record, you need a GetNew method...
> FYI,
> Karen
> Of vantagenook
> Sent: Thursday, August 20, 2009 8:34 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Can't insert with Webservices a CustUPSEmail row?
> I'm using Vantage 8.03.403C based on a Progress DB. I'm trying to
> insert a row for each customer into the CustUPSEmail table using the
> Vantage Webservices, but I'm unable to do so. I can update an
> existing row, but that doesn't help me much in getting the more than
> ten thousand rows intially in.
> I've tried setting the UPSQVSeq to 0 and also setting RowMod to A,
> but neither seem to generate an insert as expected. No error is
> returned. It just validates the packet data, then seems to ignore
> the CustUPSEmail part if that UPSQVSeq doesn't exist for that
> customer already.
> Is there a better RowMod setting than A? Would passing any RowIdent
> or DBRowIdent produce an insert? Should I use a different Webservice
> other than Customer.Update, perhaps Customer.SetUPSQVEnable (which
> I've tried with no luck) or another? The "Notify" checkbox that
> enables that section of the UI for the Customer UPS Emails is already
> set for that record so it's not something simple like that.
> Here's the packet (security header info removed):
> <soapenv:Envelope
> xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
> xmlns:web="http://epicor.com/webservices/">
> <soapenv:Header/>
> <soapenv:Body>
> <web:Update>
> <web:CompanyID>NOOK</web:CompanyID>
> <web:CustomerData>
> <CustomerDataSet>
> <Customer>
> <Company>NOOK</Company>
> <CustID>RICKTEST</CustID>
> <CustNum>12332</CustNum>
> <Name>RICK3</Name>
> <ServRef1></ServRef1>
> <ServRef2></ServRef2>
> <ServRef3>Our products make us market leaders.</ServRef3>
> <ServRef4>Our people make us world class.</ServRef4>
> <ServRef5>Thank you for choosing Nook Industres!</ServRef5>
> <UPSQuantumView>true</UPSQuantumView>
> <UPSQVShipFromName>Nook Industries, Inc.</UPSQVShipFromName>
> <UPSQVMemo>Regarding your recent order...</UPSQVMemo>
> <RowMod>[Clear=ServRef1,ServRef2]</RowMod>
> </Customer>
> <CustUPSEmail>
> <UPSQVSeq>0</UPSQVSeq>
> <EmailAddress>thecustomer@... <mailto:thecustomer%40email.com>
> </EmailAddress>
> <ShipmentNotify>true</ShipmentNotify>
> <FailureNotify>true</FailureNotify>
> <DeliveryNotify>true</DeliveryNotify>
> <EnableQuantumView>true</EnableQuantumView>
> <RowMod>A</RowMod>
> </CustUPSEmail>
> </CustomerDataSet>
> </web:CustomerData>
> </web:Update>
> </soapenv:Body>
> </soapenv:Envelope>
> Any ideas for a workaround to get rows in? We don't have
> ServiceConnect so we can't insert that way. Inserting via OBDC
> would violate our warranty. I don't know of another way so I'm stuck.
