Capture Click Event in UltraGrid from IntegerWithSpin button
I have added Spin buttons to an UltraGridColumn and need to capture the click event on those buttons, but have had no luck. The ClickCellButton event for the UltraGrid does not trigger when clicking a Spin button. Anyone know what click event on what control I should be looking for? Code below…
private void grdConnections_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs args)
  UltraGridColumn angleColumn = args.Layout.Bands[0].Columns["Angle_c"];
    angleColumn.Style = Infragistics.Win.UltraWinGrid.ColumnStyle.IntegerWithSpin;
    angleColumn.ButtonDisplayStyle = Infragistics.Win.UltraWinGrid.ButtonDisplayStyle.Always;
    angleColumn.MinValue = 0;
    angleColumn.MaxValue = 360;
  EditorWithMask angleEditor = (EditorWithMask)angleColumn.Editor;
    angleEditor.SpinIncrement = 5;
    angleEditor.SpinWrap = true;
Base on your explanation you will have to create your own even like when you use an standard control from epicor that you create the event on initialize code. You will have to create your own event.
Was able to figure it out. See below for posterity…
public class Script
  private UltraNumericEditor invertEditor;
  this.invertEditor = new UltraNumericEditor();
  this.invertEditor.EditorSpinButtonClick += new Infragistics.Win.UltraWinEditors.SpinButtonClickEventHandler(this.SpinButtonEvent);
  this.angleEditor.ButtonsRight.Add(new Infragistics.Win.UltraWinEditors.SpinEditorButton());
    angleColumn.EditorControl = this.angleEditor;
private void SpinButtonEvent(object sender, Infragistics.Win.UltraWinEditors.SpinButtonClickEventArgs args)
  //your code here
