Changing color on tabs within a form
On Aug 4, 2011 2:02 PM, "bw2868bond" <bwalker@...> wrote:
> Hmm - didnt think of overlaying the tab with another control - of course
it is probably impossible to place anything there....
> I ended up setting the background color of the panel and then
showing/activating it or closing it depending on the condition.
How about a lower tech solution? Why not add a asterisk to the tab name when
there's a comment?
Mark W.
I have been given a request to add a new tab under the Comments tab in Part Maintenance called General. That part is done. Now the user is asking if I can change the color on the tab itself if comments have been entered.
I know the color of the entire sheet can be changed, but I don't see a way to affect the tab.
Has anyone ever done this?
You can probably do it with the Rule Wizard, if you use a custom action.
Just get an instance of the tab and change the color. Should be fairly
trivial
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
> to affect the tab.
In V8, getting an instance of the tab is not a trivial thing...
I too, searched for a way to just alter the tab portion of the panel/sheet and was unable to come up with one. If anyone has has come up with a way, could you share with the group?
bw
> trivial
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > to affect the tab.
Actually I just looked into it a bit, the control doesn't expose that
property even if you could get a hold of it. The only way to do it is to
override the OnPaint method. Which frankly is too much.
only thing I can recommend is maybe making a little square label and put it
on top of the tab on the corner and have it change colors.. That would work.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> bw
> > trivial
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> Part
> if I
> way
> > > to affect the tab.
Hmm - didnt think of overlaying the tab with another control - of course it is probably impossible to place anything there....
I ended up setting the background color of the panel and then showing/activating it or closing it depending on the condition.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > bw
> > > trivial
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > Part
> > if I
> > way
> > > > to affect the tab.
You cn place a contorl there I did it, it looks kid of funky but if you do a
small enough say a 4 by 4 pixel square its probably ok
*Jose C Gomez*
*Software Engineer*
E: jose@...
> it
> work.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> panel/sheet
> way,
> > > bw
> action.
> fairly
> > > > trivial
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> in
> > > Part
> asking
> > > if I
> entered.
> see a
> > > way
> > > > > to affect the tab.
