Hi there
Not that this will help but this is a problem in 8.03.405a as well, we have raised this as an issue and had the same silence you are experiencing. This affects us more when a user changes the customer on the order to a customer with different currency set, the customer changes but the currecny stays the same unless you remove the lines first. This is nasty as if the user doent notice the invoice goes out at the original incorrect currency.
I imagine that Epicor will come back with the "Working as Designed" as if the currency changes on the header it would need to update all the lines and convert the line values to match exchange rate or use an different pricve list for differenct currency's otherwise they would all be wrong.
--- In vantage@yahoogroups.com, "m_sprowles" <msprowles@...> wrote:
> We recently upgraded from 8.03.407b to 9.04.506c, (8/29). We have had many bug issues with Epicor but one they don't seem to have an answer for is Why can't we change currencies on an existing order? We now have to delete the line items and reenter them with the new currency. Are we doing something wrong? Is it another "operating as designed" issue or is it yet another bug in 9.04?
> Any help would be appreciated.
