Thanks Randy! I appreciate the advice!
Randy Weber
Sent: Thursday, December 17, 2009 5:07 PM
Subject: RE: [Vantage] Re: Conversion from 6.1 to Epicor 9 - Questions
Tim,
We upgraded from 6.1 to 8.0 then quickly to 8.3x earlier this year. I
strongly recommend you perform a dump and load on your live 6.1 database
before trying to convert to 8x. The conversion process took about twenty
hours for us to complete before we did the dump and load on 6.1. After
that, it took less than two hours.
Randy Weber
Behalf
Of Tim
Sent: Tuesday, December 15, 2009 12:23 PM
Subject: [Vantage] Re: Conversion from 6.1 to Epicor 9 - Questions
We are in the same boat; currently using V6 looking to go E9. I have
been told that it is easiest to upgrade to V8.3 before going to E9 and
that BOM, assemblies and other inventory and cost issues are the biggest
headaches.
We haven't done any cost/benefit analysis of making the jump. There are
a few whistles and bells that E9 has that are attractive but not sure
worth the cost.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
"michaelfasci" <michaelfasci@...> wrote:
our current version 6.1. Over the years our database has become somewhat
cluttered with old data and master files that we would prefer to remove,
so our current plan at this point is to convert with Epicor's assistance
by performing a "master table only" conversion and a reimplementation
process. If you company has taken a similar approach and has performed a
like conversion, I would be interested in hearing any pitfalls, issues,
or unforeseen resource requirements that were necessary to get your
system back up and running under version 9 or even 8.
you were able to address any data or master files which youu considered
obsolete.
Randy Weber
Tim,
Randy Weber
Behalf
Of Tim
headaches.
worth the cost.
>We have been using Vantage for approximately 12 years from version 3 to
> We are in the planning stages for moving from version 6.1 to Epicor 9.
>would be also interested in the success from 6.1 to 9, and how, or if,
> For those companies that have converted bring over all their data, I
obsolete.
> I appreciate any feedback you can supply.
