Convert Date Field to YYYY-MM-DD
Thanks Jim I'll give that a try
On Monday, November 25, 2013 2:48 PM, "jckinneman@..." <jckinneman@...> wrote:
<div id="ygrps-yiv-1388489865yiv4428492013ygrp-text">
  <div>You may need to break it up into the components and them put it together the way you want.</div><div><br clear="none"></div><div style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;">MyDate = String(Year(checkhed.checkdate)) + &quot;/&quot; + string(Month(checkhed.checkdate), &quot;99&quot;) + &quot;/&quot; + String(Day(checkhed.checkdate), &quot;99&quot;).</div><div style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;"><br clear="none"></div><div style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;">Syntax may need a little tweaking.</div><div style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;"><br
clear=“none”>
Jim Kinneman
Encompass Solutions, Inc
—In vantage@yahoogroups.com, <mjfw2003@…> wrote:
I have a calculated field to convert checkhed.checkdate to YYYY/MM/DD. Based on other postings I tried
STRING(ISO-DATE(Checkhed.Checkdate)) but getting a SQL  Server Native client error
Can anyone tell me the correct expression?
</div>
<div class="ygrps-yiv-1388489865yiv4428492013yqt3240728824" id="ygrps-yiv-1388489865yiv4428492013yqt69384"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013 -- #ygrps-yiv-1388489865yiv4428492013ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mkp #ygrps-yiv-1388489865yiv4428492013hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mkp #ygrps-yiv-1388489865yiv4428492013ads {
margin-bottom:10px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mkp .ygrps-yiv-1388489865yiv4428492013ad {
padding:0 0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mkp .ygrps-yiv-1388489865yiv4428492013ad p {
margin:0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mkp .ygrps-yiv-1388489865yiv4428492013ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-sponsor #ygrps-yiv-1388489865yiv4428492013ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-sponsor #ygrps-yiv-1388489865yiv4428492013ygrp-lc #ygrps-yiv-1388489865yiv4428492013hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-sponsor #ygrps-yiv-1388489865yiv4428492013ygrp-lc .ygrps-yiv-1388489865yiv4428492013ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013activity span {
font-weight:700;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013activity span span {
color:#ff7900;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013activity span .ygrps-yiv-1388489865yiv4428492013underline {
text-decoration:underline;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013attach div a {
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013attach label a {
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013bold a {
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 dd.ygrps-yiv-1388489865yiv4428492013last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 dd.ygrps-yiv-1388489865yiv4428492013last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 dd.ygrps-yiv-1388489865yiv4428492013last p span.ygrps-yiv-1388489865yiv4428492013yshortcuts {
margin-right:0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013attach-table div div a {
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013attach-table {
width:400px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013file-title a, #ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013file-title a:active, #ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013file-title a:hover, #ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013file-title a:visited {
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013photo-title a, #ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013photo-title a:active, #ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013photo-title a:hover, #ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div.ygrps-yiv-1388489865yiv4428492013photo-title a:visited {
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 div#ygrps-yiv-1388489865yiv4428492013ygrp-mlmsg #ygrps-yiv-1388489865yiv4428492013ygrp-msg p a span.ygrps-yiv-1388489865yiv4428492013yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013green {
color:#628c2a;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 o {
font-size:0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013photos div {
float:left;width:72px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013reco-category {
font-size:77%;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013reco-desc {
font-size:77%;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 .ygrps-yiv-1388489865yiv4428492013replbq {
margin:4px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mlmsg select, #ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 input, #ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mlmsg pre, #ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 code {
font:115% monospace;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-mlmsg #ygrps-yiv-1388489865yiv4428492013logo {
padding-bottom:10px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-msg p#ygrps-yiv-1388489865yiv4428492013attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-reco #ygrps-yiv-1388489865yiv4428492013reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-sponsor #ygrps-yiv-1388489865yiv4428492013ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-sponsor #ygrps-yiv-1388489865yiv4428492013ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-sponsor #ygrps-yiv-1388489865yiv4428492013ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1388489865 #ygrps-yiv-1388489865yiv4428492013 #ygrps-yiv-1388489865yiv4428492013ygrp-vital ul li:last-child {
border-right:none !important;}
I have a calculated field to convert checkhed.checkdate to YYYY/MM/DD. Based on other postings I tried STRING(ISO-DATE(Checkhed.Checkdate)) but getting a SQL  Server Native client error
MyDate = String(Year(checkhed.checkdate)) + "/" + string(Month(checkhed.checkdate), "99") + "/" + String(Day(checkhed.checkdate), "99").
Jim Kinneman
