Creating Reports - what is the best tool?
From the DSN properties select the advanced tab and then select "Read
Uncommitted" from the "default isolation level" drop down.
Gerard M Wadman
Sr. Network Systems Engineer
Scandius BioMedical Inc.
11A Beaver Brook Road
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
http://www.scandius.com/
Of acp2g99
Sent: Wednesday, January 17, 2007 2:34 PM
Subject: [Vantage] Re: Creating Reports - what is the best tool?
Can you please offer how you set up "your ODBC users setup for "Read
Uncommitted"?
I am new to Vantage. We have a number of users that want to be able to
create reports with Vantage data. A couple of them can use Crystal
Reports, but the number of people is always growing.
I have setup a couple uses to use ODBC with either Access or Excel.
They love it.
Are there any drawbacks to letting users use the ODBC connection?
What about creating a backup of the DB (updated weekly) and letting
users pull data from there?
Thanks for your thoughts.
James
As long as you keep your ODBC users setup for "Read Uncommitted" you
should be fine letting them use Access or Excel to create custom
reports.
The majority of custom reports my users reference I created in Excel
linked via MS Query.
What's the first thing any user asks for once they see a report
generated in a web browser, Crystal or any other reporting tool?
"This is great! Now how can I get this into Excel?"
Sad but true! :-)
Jim Kennedy
Manager, Information Technologies
Firstmark Aerospace Corporation
1176 Telecom Drive
Creedmoor, North Carolina 27522-8294
Office: (919) 956-4264
FAX: (919) 682-3786
Cell: (919) 697-9410
jkennedy@... <mailto:jkennedy@...>
www.firstmarkaerospace.com <http://www.firstmarkaerospace.com/>
www.firstmarkcorp.com <http://www.firstmarkcorp.com/>
Of okeefe_01
Sent: Wednesday, January 10, 2007 6:54 PM
Subject: [Vantage] Creating Reports - what is the best tool?
They love it.
James
Using ODBC, your entire database is open for review. This can be
dangerous if you have confidential information such as employee
information, financial information or cost information that you don't
want disclosed. Using ODBC, vantage security is thrown out the window.
Since the tables are integrated in one file, Windows/Linux security is
also no good.
This is why the BAQ's are so important. BAQ security can be controlled
by menu maintenance. And with 8.03 and BAQ reports, the situation is
better.
Charlie Smith
Smith Business Services / 2W Technologies LLC
www.vistaconsultant.com <http://www.vistaconsultant.com/> /
www.2wtech.com <http://www.2wtech.com/>
Of okeefe_01
I have setup a couple uses to use ODBC with either Access or Excel. They
love it.
<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007183/msg
Id=54093/stime=1168473462/nc1=3848550/nc2=3848642/nc3=3>
I prefer Crystal. It gives a huge amount of power for manipulating
data. If needed, it also exports easily into Excel / Access / PDF....
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of okeefe_01
They love it.
James
Setting up ODBC connections will work but keep in mind that each
connection has the potential to create record locks thus causing an
increase in DB waits.
When you setup a DSN on a client computer, click on the advanced tab and
select "Read Uncommited" as the connection type. Doing this will
minimize record locks and it will also prevent the users from writing to
the DB.
Crystal is the preffered third party reporting reporting app, but Access
and Excel can certainly be used if that's what your users prefer.
I personally prefer Access as it is way more powerful than Crystal IMO.
If you are comfortable navigating at the DB level, I would suggest
creating multiple user schema's with various privileges and then create
views within them. Then assign those user credentials to the DSN on the
appropriate clients, this will ensure that curious users don't take it
upon themselves to snoop around within the Vantage tables.
Cheers
Of okeefe_01
They love it.
James
I think that a ODBC Connection may also take a license. Depending on
the volume of users and the reporting there might a performance
issue. But Gerards comments are the priority ones whether there is
one or hundred users.
If you have corvu, it takes a snapshot of the vantage database, then
you could report off this and not the live database. However, corvu
is a different product completely and I don't think you directly
access it through microsoft office products.
tab and
writing to
> the DB.
Access
IMO.
create
the
it
> Cheers
Behalf
> Of okeefe_01
to
> They love it.
> James
To me...the question is not "which tool" but allowing users to create reports in the first place. Generally anyone outside of IT, in a line or staff position that depends on the data from the reports, are either unqualified to develop a report that provides accurate information or too deep into the results to recognize any bias introduced into the reporting. I have found the few "cross over" people who can develop and self-audit a report to be very rare. More often turning over a reporting tool (and access, even read-only, to the database) is asking for trouble.
Case in point....a former CFO who developed his own spreadsheets from extracted data and did not know his running totals were wrong. He used the report for several years and transfered elsewhere. His successor (a good friend of mine), after a couple more years, found the problem and determined an inventory write off of $200K was needed. Because he had relied on the accuracy of the report and despite his having found the problem (and four years of outside auditors NOT finding it!) he was fired. All because of a simple misunderstanding of running totals and failure to internally check the report.
We have many people making their own spreadsheet databases (although I prefer they don't) but at least from data on validated reports and the spreadsheets are peer reviewed.
As mentioned BAQs may be a good middle ground where IT develops an XML extract and the users can take it from there with just about anything - Access, Excel, Crystal, etc... As long as there is good oversight and control. I shake in my boots at the thought of a user doing their own BAQ or ODBC and not understanding something like assembly levels or order releases and then summarizing something at the wrong level and getting multiple occurances added up. Realisticaly should a Production Manager or Engineering Supervisor be a quasi-DBA in addition to their primary function? How many users really have time to understand a left outer join?
This concludes today's ramble on IT Philosophy. ;)
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of okeefe_01
Sent: Wednesday, January 10, 2007 5:54 PM
They love it.
James
Very true.
the report.
> -Todd C.
Behalf Of okeefe_01
to
> They love it.
> James
Not exactly true, you can create users for ODBC and apply security to
tables for the users, I.e make them read only or not at all. (however
your statement is true if you use the default (v6.1) sysprogress user)
Regards,
Stephen Edginton
Of Charlie Smith
Sent: 11 January 2007 05:03
Subject: [Vantage] ODBC drawbacks
also no good.
better.
Charlie Smith
<http://www.vistaconsultant.com/> > /
www.2wtech.com <http://www.2wtech.com/ <http://www.2wtech.com/> >
Behalf
Of okeefe_01
love it.
Which is prima facie evidence as to why it is never a good idea in Vantage
to deploy ODBC access with the default login in a production environment.
Best regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
<http://www.aspacia.com/> http://www.aspacia.com/
Stephen Edginton
Sent: Thursday, January 11, 2007 8:45 AM
Subject: RE: [Vantage] ODBC drawbacks
Regards,
Stephen Edginton
Behalf
Of Charlie Smith
also no good.
better.
Charlie Smith
Behalf
Of okeefe_01
love it.
I agree 100%. Users should not create their own reports.
At our company I am the report developer. I use Crystal and Access
depending on the situation. ODBC is safe, as far as writing to the
DB, if you set it up right. The instructions I had told me to create
a odbcuser account and give that account read rights, only IT knows
the sysprogress user id and password. I would caution about certain
situations where people could get into sensitive tables if they know
how to create their own reports or queries. We don't have any
payroll info in Vantage so its not a big worry and none of my users
know how to create an ODBC link. Nobody but IT has Crystal Reports
to develop with, and every Access application I develop has table
security built in to the DB.
Many of my users (bean counters especially) misuse Excel to an
extreme keeping track of things on their own that could easily be
pulled from the system if they'd only ask. I've seen several,
Controllers included, that don't know how to properly use formulas,
but they love their spreadsheets.
Brian Stenglein
the report.
> -Todd C.
Behalf Of okeefe_01
to
> They love it.
> James
Uncommitted"?
> Uncommitted"?
Open the Control Panel - Administrative Tools - ODBC data source
administrator. On the System DSN tab, select the Data Direct
connection - Select the configure option - go to the advanced tab - on
the default isolation level select read uncommitted.
