Crystal - Error 599
I missed Dan's thread on file DNS. Can you send it again?
Sent: Tuesday, October 01, 2002 12:26 PM
Subject: Re: [Vantage] Re: Crystal - Error 599
Lois,
Thanks for the info. Did you try the File DNS that Dan suggested? Like
I've said before, I have never gotten this process to work using the
Progress ODBC drivers that you are using. We use aftermarket Merant drivers
(3.5) and it works that way. Perhaps Dan can provide some more help for
you. I've never received a prowin32 error in your current situation, so I'm
not sure what next.
Perhaps as one more try... install Crystal but don't unistall it... Then
test to see if the report works while Crystal is installed. If it does,
then I have heard of others just deleting the .exe file for crystal instead
of fully uninstalling it.
Troy
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Tuesday, October 01, 2002 6:59 AM
Subject: RE: [Vantage] Re: Crystal - Error 599
this is win98 wkstation. It is working with Vantage off a W2k server. I
installed crystal and then uninstalled it. When I open the pack list in
Vantage and choose to print preview up comes the prowin32 error. I can
print/preview the pack list in crystal just fine. THis is ODBC Merant
3.60
32 bit Progress SQL92 v.9.1D. Vantage is 5.00.350.
Sent: Tuesday, October 01, 2002 11:50 AM
Lois,
Can you give a bit more detail? Did you install Crystal? What OS are
you
working on. At what point do you get a prowin32 error (ie. when you log
in,
when you run the report, etc). Can you print/preview the report in
Crystal
designer? Which ODBC driver are you using? Which version of Vantage?
Troy Funte
Liberty Electronics
Sent: Tuesday, October 01, 2002 6:45 AM
Did this now I get a prowin32 error... "Prowin caused an invalid page
fualt
in module crpe32.dll. What now?
Sent: Tuesday, October 01, 2002 11:21 AM
Lois,
On the workstations that use our modified POForm.rpt report (which
has
added ODBC fields) I also have to install Crystal 8.0 on each
workstation,
and then undelete it (which leaves the .dll files from Crystal on the
workstation). On XP workstations, I have to do an extra step because XP
removes all the .dll files when I uninstall. On XP workstations I
install
Crystal, then copy the whole "System32 folder" to a temporary location,
then
uninstall Crystal, then copy the whole temp folder back to the System32
folder -- answering NO to overwrite any files. This leaves only the NEW
.dll's being copied back to the System32 folder.
That should clear up your crpe32.dll error.
Troy Funte
Liberty Electronics
Sent: Tuesday, October 01, 2002 5:34 AM
Subject: [Vantage] Re: Crystal - Error 599
You do need to copy the crpe32.dll to your windows/system directory
along with the p2sodbc.dll.
HTH,
Brian Stenglein
Clow Stamping Company
--- In vantage@y..., "Heisey, Lois" <lheisey@m...> wrote:
> So how does one resolve the issue? My error says "could not load
DLL
> procedure crpe32.dll(3258). What does it mean and is there any
means to
> correct it?
> From: Ted Kitch [mailto:ted@m...]
> Sent: Monday, September 30, 2002 2:59 PM
> To: 'vantage@y...'
> These errors can also be caused due to DLL issues with Crystal. 599
> basically boils down to the ODBC driver not being able to logon to
the
> server.
> Ted Kitch
> ted@m...
> From: Babette Welch [mailto:bwelch@a...]
> Sent: Monday, September 30, 2002 7:52 AM
> To: vantage@y...
> Hello to Troy & Dan & others:
> Currently using 3.60 Merant ODBC
> Will try the
> creation of a file DNS instead of a system DNS, etc.
> It is frustrating since I had these and numerous other modified and
compiled
> reports working in
> Vantage 4.0 now I have to spend time fixing these in this enhanced
Vantage
> 5.1
> Will I continue to have problems when we change to Vantage 5.2?
> Thanks for all assistance.
> BW
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.226.9747 ext 235
> 906.228.0951 fax
must have
Builder and
> <http://groups.yahoo.com/group/vantage/files/>
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/links>
> Your use of Yahoo! Groups is subject to the Yahoo!
> <http://docs.yahoo.com/info/terms/> Terms of Service.
must have
Builder and
Yahoo! Groups Sponsor
ADVERTISEMENT
and
have
and
ADVERTISEMENT
and
have
