Crystal Report Error. Not listed in Files
Per the following posting I dug out of my postings archive.....you can download a registry fix routine from the YahooGroup archives. Troy Funte posted the following once upon a time.
-Todd C.
You might need the Outjoin registry fix for Crystal and ODBC. There is
one for the Merant 3.6 drivers on the egroups files list here
<http://f6.grp.yahoofs.com/v1/INmZP9tEn2tpZUpO1MyqT-quOLpWmsTb6HGH75qHiW42Yp9> http://f6.grp.yahoofs.com/v1/INmZP9tEn2tpZUpO1MyqT-quOLpWmsTb6HGH75qHiW42Yp9
ab2KbvNgC8r5SIZgjTofTbXi5QGs28Am4-OpRl8plOTIr/Vantage%20Admin/Crystal.reg
If you are using a different version of ODBC drivers, you may need to
contact Seagate Software (Crystal) support for the proper file. I have one
for Merant 3.5 if you happen to have that version.
Troy Funte
Sent: Tuesday, June 29, 2004 9:59 AM
Subject: RE: [Vantage] Crystal Report Error. Not listed in Files
I just started using Crystal a few months ago and used to have this same problem. To manually fix it I did this...From the report I was running I clicked on database, show sql query and then deleted the {oj} from the first and the } at the end and my report would run. To fix it permanently our administrator had to go into the registry and make some changes, sorry I don't have the exact details of what they were. I'd call epicor support they should be able to help you.
Sent: Tuesday, June 29, 2004 8:39 AM
Subject: [Vantage] Crystal Report Error. Not listed in Files
This is the error that I get when I try to refresh after adding my
fields:
ODBC error [Merant] [ODBC Progress Driver] The keywords LEFT OUTER
JOIN were not found in an outer join escape sequence.
We are running Crystal Version 8.0.
BTW: I am not using a left join in my linking. I even tried to open
some of the reports in the Files section and came up with the same
error. This is my first time using Crystal.
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129np1a6r/M=295196.4901138.6071305.3001176/D=groups/S=1705007183:HM/EXP=1088607520/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=:HM/A=2128215/rand=130266399>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
fields:
fields:
