I was given these instruction awhile back maybe they will help.
LEFT OUTER JOIN ERROR FIX
PROBLEM DESCRIPTION: Getting error: "Error Detected by Database
Dll" or "LEFT OUTER JOIN" Error when previewing Crystal Report
created against ODBC Connection to Databse
To fix this problem with Crystal 7, 8 or 8.5 do the following:
1) Save the file Outjoin File.REG. Double click on the file. This
will import the correct registry information to your workstation's
registry.
2) After adding the registry entry from step 1, you will need to
edit the registry key below adding in the following "word" depending
on the ODBC driver version you are using.
- add "pgpro915" (Merant 3.60 SQL-92 Driver for 9.1x) loaded by
default for Vantage 5.00, 5.10, 5.20, 6.00)
Add the values to the OpenIngres value in the following registry key:
To open the registry, go to [START] --> Run, type in: regedit
Click [OK].
Double click down through the path below. Locate the OpenIngres
value and double click on it. Add the correct value from above.
HKEY_CURRENT_USER\Software\Seagate Software\Crystal
Reports\DatabaseOptions\OuterJoin
Example: oplodbc,oplodb32,pgpro915
Dan Ernst
Computer Services
Correct Craft, Inc.
(407) 855-4141
http://www.correctcraft.com
registry.
Click [OK].
Dan Ernst
Computer Services
Correct Craft, Inc.
(407) 855-4141
--- In vantage@yahoogroups.com, "Mesick, Todd" <tmesick@t...> wrote:
> I have installed the patches with not luck as of yet.
> Thanks
> Todd
> -----Original Message-----
> From: Manasa Reddy [mailto:mreddy@c...]
> Sent: Thursday, June 16, 2005 8:03 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Outer join
> Todd:
> I think there was a patch you had to install for Crystal for
> the outer joins.
> Did you apply it? It should be located on Epicor's website
> where you would download patches for Vantage.
> HTH,
> M. Manasa Reddy
> ERP Specialist
> Crestview Aerospace Corporation
> Email: mreddy@c...
> Phone: (850) 682-2746 x 272
> From: vantage@yahoogroups.com
> [mailto:vantage@yahoogroups.com]On Behalf Of Mesick, Todd
> Sent: Thursday, June 16, 2005 6:45 AM
> To: 'vantage@yahoogroups.com'
> Yes, It seems to hang on the queries and never return
> anything, when I use
> them.
> Specifically I have modified the pack slip to included
> customer serial
> numbers on the pack slip.
> When there is no serial numbers I would like to use the
> outer join to
> continue processing and return the rest of the data(ie
> customer po, po line)
> Thanks for your help
> Todd
> From: Brandon Murch [mailto:bmurch@w...]
> Sent: Wednesday, June 15, 2005 4:47 PM
> Yes...is there more to the question?
> Brandon R Murch
> Supervisor of Information Technology
> WindStone Medical Packaging
> 406.259.6387
> bmurch@w...
> <mailto:bmurch@w...>
> From: Mesick, Todd [mailto:tmesick@t...]
> Sent: Wednesday, June 15, 2005 2:29 PM
> Subject: [Vantage] Outer join
> Anyone have any luck using outer joins in crystal 8.5 with
> progress
> 9.1d?
> Thanks
> Todd Mesick
> TECT Proprietary & Confidential. This message, along with
> any
> attachments,
> is intended only for the exclusive use of the individual
> or entity to
> which
> it is addressed and may contain information that is
> privileged,
> confidential
> and exempt from disclosure. If you are not the intended
> recipient, you
> are
> hereby notified that any dissemination, distribution, or
> copying of this
> message, or any attachment, is strictly prohibited. If
> you have
> received
> this message in error, please notify the original sender
> immediately by
> return email, or by calling 229-228-2600, and delete the
> message, along
> with
> any attachments, from your computer.
> Useful links for the Yahoo!Groups Vantage Board are: (
> Note: You must
> have already linked your email address to a yahoo id to
> enable access. )
> (1) To access the Files Section of our Yahoo!Group for
> Report Builder
> and Crystal Reports and other 'goodies', please goto:
> <http://groups.yahoo.com/group/vantage/files/.>
> < http://groups.yahoo.com/group/vantage/files/.
> <http://groups.yahoo.com/group/vantage/files/.> >
> <http://groups.yahoo.com/group/vantage/files/>
> <http://groups.yahoo.com/group/vantage/files/> > >
> <http://groups.yahoo.com/group/vantage/messages>
> < http://groups.yahoo.com/group/vantage/messages
> <http://groups.yahoo.com/group/vantage/messages> >
> (3) To view links to Vendors that provide Vantage services
> goto:
> <http://groups.yahoo.com/group/vantage/links>
> < http://groups.yahoo.com/group/vantage/links
> <http://groups.yahoo.com/group/vantage/links> >
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> <http://groups.yahoo.com/group/vantage/>
> <http://groups.yahoo.com/group/vantage/> >
> * To unsubscribe from this group, send an email
> to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscr
> ibe>
> * Your use of Yahoo! Groups is subject to the
> Yahoo! Terms of
> Service < http://docs.yahoo.com/info/terms/
> <http://docs.yahoo.com/info/terms/>
<http://docs.yahoo.com/info/terms/> >
> Note: You must have
> already linked your email address to a yahoo id to enable
> access. )
> Report Builder and
> goto:
> _____
> Yahoo! Groups Links
> * To unsubscribe from this group, send an email to:
> ibe>
> * Your use of Yahoo! Groups is subject to the Yahoo!
> Terms of Service
> any attachments,
> or entity to which
> privileged, confidential
> recipient, you are
> copying of this
> you have received
> immediately by
> message, along with
> Note: You must have already linked your email address to a
> yahoo id to enable access. )
> Report Builder and Crystal Reports and other 'goodies',
> please goto: http://groups.yahoo.com/group/vantage/files/.
> goto: http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups Links
> a.. To visit your group on the web, go to:
> b.. To unsubscribe from this group, send an email to:
> c.. Your use of Yahoo! Groups is subject to the Yahoo!
> Terms of Service.
must have
Builder and
> _____
> Yahoo! Groups Links
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
> <http://docs.yahoo.com/info/terms/> .
> TECT Proprietary & Confidential. This message, along with any
attachments,
> is intended only for the exclusive use of the individual or entity
to which
> it is addressed and may contain information that is privileged,
confidential
recipient, you are
> hereby notified that any dissemination, distribution, or copying
of this
> message, or any attachment, is strictly prohibited. If you have
received
immediately by
> return email, or by calling 229-228-2600, and delete the message,
along with
