Could you post your SQL query and record selection formula?
--- In vantage@yahoogroups.com, "davek2127" <davek2127@...> wrote:
> We are in the process of upgrading from 6.1 to 8.0. We have created
a
> Crystal Report (version 8.5) that accesses Progress thru on ODBC
> datasource (MERANT 3.60 32-BIT Progress SQL v9.1D). The outside
> vendor report joins several tables together and then uses this to
> make selections for our report. When we run the report, we get the
> following error
> ODBC error:[DataDirect-Technologies][ODBC PROGRESS driver][PROGRESS]
> MM-Insertion error (7718)
> We have been unable to find what this error might mean. Strangely
> enough, however, when we remove the record selection within the
> report it runs fine. Has anyone ever experienced this behavior when
> trying to do record selection based on 2 different joined tables in
a
> Crystal Report? We have other reports that do record selection
just
> fine - this one is a real mystery.
> Best regards,
> Dave Kwiatkowski
> Barber-Nichols Inc.
