Odbc
We are experiencing problems with our ODBC set up. It appears to be running
fine on the server but when we try to set up the client installation we are
getting the two following errors. 2575 and 1890. Has anyone experienced this
problem and if so any suggestions ? all suggestions from epicor support are
not working.
Regards
Ian Chatwin
What version of Vantage, which ODBC driver are you using, at what point do you get the errors?
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Monday, June 11, 2001 7:10 AM
Subject: [Vantage] ODBC
not working.
Regards
Ian Chatwin
Yahoo! Groups Sponsor
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
We are on Vantage 4 and the ODBC is Merant V3.6. We get the error messages
while trying to set up the workstation.
Passing on the description from our IT guy = start-settings-control
panel-ODBC-highlight progress-configure-test connect -ok, we then get the
error messages.
Regards
Ian
sentto-20369-21654-992264115-ian=verniersprings.com@...
[mailto:sentto-20369-21654-992264115-ian=verniersprings.com@...
ist.com]On Behalf Of Troy Funte
Sent: 11 June 2001 13:55
Subject: Re: [Vantage] ODBC
you get the errors?
Troy Funte
Liberty Electronics
running
are
this
are
not working.
Regards
Ian Chatwin
What is the text of the two error messages that you get?
Troy Funte
Liberty Electronics
Sent: Monday, June 11, 2001 9:11 AM
Subject: RE: [Vantage] ODBC
error messages.
Regards
Ian
you get the errors?
Troy Funte
Liberty Electronics
running
are
this
are
not working.
Regards
Ian Chatwin
The following is from Epicor's ODBC install guide, Appendix A. I have never
personally come across these errors, however here's what their guide says
about them, it may help you out...
4. 'Error establishing Open Interface Driver connection (2575)'
A) In most cases this error is accompanied with another message: like '1403:
You have not supplied a parameter for argument -cpterm'. Try to resolve that
other message first. In this specific case removing/completing the -cpterm
line in the startup.pf file (on client/server machine) solves the problem.
Be sure that you restart the Progress Server/Broker after you edit the
startup.pf file.
9. 'Broker : Could not spawn server (1890)'
A) Check the existence of the PROOIBRK and PROOIDRV variables on the
Server-machine. They must point to the correct executables (Broker and OID).
B) Check the version of your Progress Database (must be at least 7.3B03)
C) Check the lg-files (prooidrv.lg and dcdv7.lg) for more information
The text is as follows. (MERANT)(ODBC PROGRESS driver)(PROGRESS)Broker :
Could not spawn server (1890) click OK and then
(MERANT)(ODBC PROGRESS driver)(PROGRESS)Error establishing Open Interface
Driver Connection (2575).
I hope this helps.
Ian
sentto-20369-21657-992267111-ian=verniersprings.com@...
[mailto:sentto-20369-21657-992267111-ian=verniersprings.com@...
Sent: 11 June 2001 14:45
Troy Funte
Liberty Electronics
error messages.
Regards
Ian
you get the errors?
Troy Funte
Liberty Electronics
running
are
this
are
not working.
Regards
Ian Chatwin
already
already
I am having a lot of difficulty with ODBC and Crystal Reports. I want to
take the Crystal Class but it is not until August and in Boston.
When I create a report with a join I get the following error: ODBC Error:
[Merant][ODBC PROGRESS driver] The keywords LEFT OUTER JOIN were not found
in an outer join escape sequence.
I don't even have any left outer joins in the report.
On another reports, I am getting the following error: ODBC Error:
[Merant][ODBC PROGRESS driver] [PROGRESS] Syntax error (7587)
Is anyone familiar with this error? Also, where can I go to find out what a
7587 error is.
Thanks for your help.
De Anna Godfrey
V.P.
McNeal Enterprises, Inc.
2031 Ringwood Avenue
San Jose, CA 95131-1703
Phone: 408.922.7290
Fax: 408.922.0728
I was told by Crystal Decisions that generally, the last [braketed] name in an error is the place to look for help. In the case of your 7587 error, that would be PROGRESS. Here is the text of one occurrence of error 7587 on their website http://www.progress.com/services/support/cgi-bin/techweb-kbase.cgi/webkb.html?TAB=querye&verrnum=7587&vwfilters=%28none%29&kbt=_self&vmaxentries=100&btnOP.x=61&btnOP.y=12
-- Syntax Error (7587)
Solution: Check your SQL statement. If the field name contains
reserved characters ("), (_) or (-), enclose your field name
in double quotation marks ("). For example, to display all
user names and the user ID, enter this syntax into the
Procedure Editor: "SELECT _userid, _user-name
FROM _user ORDER BY _userid ASC
In Visual Basic, you must use double quotation marks ("):
"SELECT " + Chr(34) + "_userid" + Chr(34) + " FROM PUB." +
Chr(34) +"_user"+Chr(34)
There were a couple other results that came from that error in their knowledgebase that you may want to look up. see
to look up error messages.
To: Vantage
Sent: Wednesday, June 13, 2001 4:49 PM
7587 error is.
De Anna Godfrey
V.P.
Phone: 408.922.7290
Fax: 408.922.0728
www.
Having said all that about looking up PROGRESS errors. I would advise calling Crystal Decisions (if you have any more free support left on your 60 day limit). They can usually track down why SQL statements are being generated correctly. Usually they will advise you to start the report from scract, starting with one table and a few fields. Refresh the report. Then add another table, add a field from that table, and Refresh the report. Try doing that until you have built the report again and not when the error shows up. I have had reports that didn't work, but when I went throught he above -step-by-step- procedure, there were no errors. Apparently Crystal has trouble creating the SQL statement for Progress with complex joins at times.
It may be a place for you to start anyway.
Troy Funte
Liberty Electronics
To: Vantage
7587 error is.
De Anna Godfrey
V.P.
Phone: 408.922.7290
Fax: 408.922.0728
www.
Merant has a knowledge base that lets you search ODBC error messages, here's
the address:
<http://knowledgebase.merant.com/cgi-bin/webcgi.exe?new,kb=DataDirect,Templa
teSet=MERANT8>
http://knowledgebase.merant.com/cgi-bin/webcgi.exe?new,kb=DataDirect,Templat
eSet=MERANT8
Sent: Wednesday, June 13, 2001 3:50 PM
To: Vantage
7587 error is.
De Anna Godfrey
V.P.
Phone: 408.922.7290
Fax: 408.922.0728
www.
<http://us.adserver.yahoo.com/l?M=201903.1442209.3019422.1252795/D=egroupmai
l/S=1700007183:N/A=666067/rand=661081950>
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
<http://docs.yahoo.com/info/terms/> Service.
Thank you, Ed. I downloaded and applied the fix posted by Epicor. I do not
have any problem connecting and getting all the tables I need using win2k.
Thank you all!
Mario Aguirre
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
Sent: Tuesday, October 02, 2001 10:48 AM
From our experience, you have to use SQL89 with
Vantage 5.0 and Merant 3.60 32bit ODBC driver to
have any luck with ODBC.
Contact Epicor as they have a couple start and stop
.BAT files to help make this work. They should also
have instructions on exactly what you need to do.
Ed Kulbacki
--- Mario Aguirre <maguirre@...> wrote:
> I am trying to connect to Vantage 5.0 using the
> ODBC-Merant 3.60 32bit
> Progress SQL92 v9.1A driver and link tables to MS
> Access (97-2002). I was
> able to link all the tables needed with the
> exception of PUB._Shipdtl. The
> error message said:
> "ODBC-call failed.
> [MERANT][ODBC PROGRESS driver][PROGRESS]Column_Desc
> in table PUB._Index has
> a value exceeding its max length or precision.
> (#-210012)"
> We use Access to generate EDI ASN's, etc. Is anybody
> in the group familiar
> with these error messages? I tried both Progress and
> Microsoft web sites.
> Progress knowledge database seems off line all the
> time. Office XP has a
> couple of entries about ODBC and none of them relate
> to this error
> message...
> Mario Aguirre
> Lakin General
> removed]
__________________________________________________
Do You Yahoo!?
Listen to your Yahoo! Mail messages from any phone.
http://phone.yahoo.com
I may be wrong but I don't believe there is a solution. Merant ODBC can
only handle so many thousands of characters. Many of the memo fields in
Vantage will cause this error. The only solution I have found was to export
the table to a text file and link to that.
Jeremy Leonard
IT Manage
K-T Corporation
Sent: Wednesday, May 14, 2003 1:48 PM
Hi,
I am getting the following error when running a crystal report from
ODBC. Dose anyone know a work around? Any help would be appreciated.
" ODBC error: [MERANT][ODBC PROGRESS driver][PROGRESS]Column CommentText
in table PUB.JobHead has value exceeding max length or precision."
If I remove the JobHead.commentText field from the report it runs fine.
Ron Newell
IT Manager
Pattison Sign Group
165 Waterloo Ave.
Penticton, BCÂ V2A 7J3
Phone: 250-492-4522 EX:101
Fax: 250-492-3462
Â
Â
http://www.pattisonsign.com
mailto:rnewell@...
Sent: Thursday, May 15, 2003 10:23 AM
Ron,
I have never run into that error with a comment field, but have had
similar problems with the part description field, which is also a l o n g
field (blob, it is sometimes called). Crystal doesn't let you use formulas
on blob or memo fields that are beyond 250 characters. The answer in
Crystal is to use an expression that truncates the field to 250 characters.
Then it seems you can use it in formulas and groups.
Troy
Sent: Wednesday, May 14, 2003 2:48 PM
Hi,
Ron Newell
IT Manager
Pattison Sign Group
165 Waterloo Ave.
Penticton, BC V2A 7J3
Fax: 250-492-3462
http://www.pattisonsign.com <http://www.pattisonsign.com>
mailto:rnewell@...
<http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=17050071
83:HM/A=1564416/R=0/*http://www.netflix.com/Default?mqso=60164797&partid=317
0658>
<http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egroupmai
l/S=:HM/A=1564416/rand=111257204>
Should ODBC config be set for 4GL, SQL or both? I can't remember
when this was first set up what that was set to.
I believe you need to set it up with both SQL and 4GL. I may have missed
this response in a previous post, but have you tried uninstalling and
reinstalling the latest ODBC driver?
Thanks.
dave
National Coupling Company, Inc.
Office: 281.499.2583
Fax: 281.499.5941
Direct: 281.208.6715
Cell: 281.352.2793
Sent: Tuesday, September 23, 2003 8:37 AM
ADVERTISEMENT
HYPERLINK
"http://rd.yahoo.com/M=194081.3897168.5135684.1261774/D=egroupweb/S=1705
007183:HM/A=1732161/R=0/SIG=11p5b9ris/*http:/www.ediets.com/start.cfm?co
de=30509&media=atkins"click here
HYPERLINK
"http://us.adserver.yahoo.com/l?M=194081.3897168.5135684.1261774/D=egrou
pmail/S=:HM/A=1732161/rand=629541383"
and Crystal Reports and other 'goodies', please goto: HYPERLINK
"http://groups.yahoo.com/group/vantage/files/"http://groups.yahoo.com/gr
oup/vantage/files/.
(2) To search through old msg's goto: HYPERLINK
"http://groups.yahoo.com/group/vantage/messages"http://groups.yahoo.com/
HYPERLINK
"http://groups.yahoo.com/group/vantage/links"http://groups.yahoo.com/gro
up/vantage/links
Your use of Yahoo! Groups is subject to the HYPERLINK
"http://docs.yahoo.com/info/terms/"Yahoo! Terms of Service.
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.518 / Virus Database: 316 - Release Date: 9/11/2003
Outgoing mail is certified Virus Free.
No I have not tried that. Can someone 1st confirm the "both" setting?
Also, where will I get the latest driver?
Sent: Tuesday, September 23, 2003 9:26 AM
Thanks.
dave
Fax: 281.499.5941
Cell: 281.352.2793
ADVERTISEMENT
HYPERLINK
HYPERLINK
oup/vantage/files/.
HYPERLINK
up/vantage/links
Ours, 6.0 Default has the ODBC group set to SQL only.
Aaron Hoyt
Design Standards
Sent: Tuesday, September 23, 2003 10:27 AM
To: 'vantage@yahoogroups.com'
Thanks.
dave
Fax: 281.499.5941
Cell: 281.352.2793
ADVERTISEMENT
HYPERLINK
HYPERLINK
oup/vantage/files/.
HYPERLINK
up/vantage/links
We are on 5.0 so does that make a difference?
Sent: Tuesday, September 23, 2003 9:48 AM
Aaron Hoyt
Design Standards
Thanks.
dave
Fax: 281.499.5941
Cell: 281.352.2793
ADVERTISEMENT
HYPERLINK
HYPERLINK
oup/vantage/files/.
HYPERLINK
up/vantage/links
When we were on 5.0 we only had one server group. It was set to both. In
6.0 they split up the group to vantage sessions with 4GL only and ODBC
sessions with SQL only. I am not sure, the reason, so I won't guess, but
that is a change. So if you are setting up 5.0 for access by both vantage
and ODBC, I would say use the both setting.
Aaron
Sent: Tuesday, September 23, 2003 10:52 AM
Aaron Hoyt
Design Standards
Thanks.
dave
Fax: 281.499.5941
Cell: 281.352.2793
ADVERTISEMENT
HYPERLINK
HYPERLINK
oup/vantage/files/.
HYPERLINK
up/vantage/links
I am going to change it to both and reboot the server and watch what
happens.
Sent: Tuesday, September 23, 2003 10:07 AM
Aaron
Aaron Hoyt
Design Standards
Thanks.
dave
Fax: 281.499.5941
Cell: 281.352.2793
ADVERTISEMENT
HYPERLINK
HYPERLINK
oup/vantage/files/.
HYPERLINK
up/vantage/links
