Crystal report PO form, how to add terms and conditions sheet as
OK, Thanks that worked great....
--- In vantage@yahoogroups.com, "howco22" <agortman@...> wrote:
> you will want to add the formula to the "Suppress(No Drill-Down)" formula box.
> --- In vantage@yahoogroups.com, "howco22" <agortman@> wrote:
> > formula should be "Pagenumber > 1"
> > > Ok,
> > > go to the section header, click on page header ( top level) then add a formula of pagenmber > 1
> > > that should will suppress all page headers on all pages except page 1.
> > > if I recall it took a while to figure it out.
> > > however, if you have many lines & you actual po is more than one page, (without the T&C) then it will not print any header info on page 2 etc.
> > > --- In vantage@yahoogroups.com, "jamesd" <jdaniel1127@> wrote:
> > > > setting reset page number didn't help.
> > > > What prints out is the complete po on page 1.
> > > > On page 2 is the page header b,c,d,e,f,g then the first half of the T&C text.
> > > > On page 3 is the page header b,c,d then the seond half of the T&C text.
> > > > If you want to look at what prints out or the crystal rpt file I can send them to you if I have your email..
> > > > Thanks,
> > > > James
> > > > jdaniel1127@
> > > > > I have one more note I forgot to mention, we unchecked "reset page number after" on group footer "B"
> > > > > see if that helps solve your issue. What sections are printing on the terms page?
> > > > > I have it set up so that our terms section prints on the last page for each PO.
> > > > > > Tried adding the Group footer and now I get the report header on every page with the T&C split across 2 pages, I did get rid of the blank page. Just need to get the header info off of the T&C pages.
> > > > > > --- In vantage@yahoogroups.com, Ted Koch <tkoch77@> wrote:
> > > > > > > One of my reports is set up with the terms in footer b, in the section expert for footer a I have new page after checked.
> > > > > > > ________________________________
> > > > > > > From: "jdaniel1127@" <jdaniel1127@>
> > > > > > > To: vantage@yahoogroups.com
> > > > > > > Sent: Friday, September 23, 2011 7:24 PM
> > > > > > > Subject: Re: [Vantage] Re: Crystal report PO form, how to add terms and conditions sheet as the last page
> > > > > > > ok, tried both solutions and it still comes out wrong. If I don't add the T&C it prints one page. If I add T&C text to a report footer or group footer I get 3 pages after the first one with all of the header info on each page, T&C on 2 pages and a blank page with just the header...
> > > > > > > ----- Original Message -----
> > > > > > > From: jdaniel1127@
> > > > > > > Sent: Thursday, September 22, 2011 8:25:47 PM
> > > > > > > Â
> > > > > > > ok, thanks I will try that...
> > > > > > > From: "howco22" < agortman@ >
> > > > > > > Sent: Thursday, September 22, 2011 2:10:32 PM
> > > > > > > Subject: [Vantage] Re: Crystal report PO form, how to add terms and conditions sheet as the last page
> > > > > > > Â
> > > > > > > I've done this by adding the terms in a new Group Footer, checking new page before, and reset page number after.
> > > > > > > works great!
> > > > > > > --- In vantage@yahoogroups.com , "jamesd" <jdaniel1127@> wrote:
> > > > > > > > added a new report footer(c) and copied in the text and checked the new page, keep together and can grow boxes. Now it prints the po on page 1 of 1 and then prints 2 pages with the header data and 1/2 of the T&C on each of those 2 pagers then sends out a blank with just header data.... I have a pdf printout of it, the original was just 1 of 1..
> > > > > > > > --- In vantage@yahoogroups.com , Tony Hughes <thughes281@> wrote:
> > > > > > > > > James,
> > > > > > > > > You do it on the crystal report, not as an appended file, but as text on the actual report (.rpt).
> > > > > > > > > On the PO form .rpt file, add a new Report Footer, set a check in "New Page Before" and "Keep Together".
> > > > > > > > > In that Report Footer B - add your text object, make sure it is set to "Can Grow" and enter your text there.
> > > > > > > > > If you already have multiple Report Footers, just make sure the one you are using for the T&C is the highest lettered Report Footer.
> > > > > > > > > Let me know if you need more help.
> > > > > > > > > --- On Wed, 9/21/11, jamesd <jdaniel1127@> wrote:
> > > > > > > > > From: jamesd <jdaniel1127@>
> > > > > > > > > Subject: [Vantage] Crystal report PO form, how to add terms and conditions sheet as the last page
> > > > > > > > > Date: Wednesday, September 21, 2011, 9:39 PM
> > > > > > > > > ÂÂ
> > > > > > > > > Have a Crystal Xi report for the PO form and a pdf file of our terms and conditions ( 1 page) that I want to add as the last page when the PO is created so it shows up when we print it or preview it. It would get saved and emailed to our suppliers... How would I do this, I assume it would be done in Crystal and not Vantage 8.03.408B?
> > > > > > > > > [Non-text portions of this message have been removed]
> > > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> > > > > > > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> > > > > > > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > > > > > > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
James,
Â
ok, will try this tomorrow. I was looking in crystal reports xi to add it somewhere and not having much luck..
Sent: Wednesday, September 21, 2011 5:57:10 PM
Subject: Re: [Vantage] Crystal report PO form, how to add terms and conditions sheet as the last page
Â
James,
Â
Not sure if this applies, but if you are ever intending to send the PO out using Epicor Advanced Print Management (aka Doc-link) then there is the opportunity to attach the PDF as a "supplemental document" to the outbound PO email.
See other posts on APM on this forum.
Sorry just re-read your original email properly this time. You say you are saving and emailing your PO's. In this situation you definitely want to be considering APM. Especially if you ever intend to email remittance advice documents and AR invoices the same way. Some of our customers do batch PO print from the Purchase Suggestions screen, and in this case they send dozens at a time. APM fully automates this and can accommodate where suppliers demand to have the PO by fax or hardcopy.
--- In vantage@yahoogroups.com, Tony Hughes <thughes281@...> wrote:
> James,
> From: jamesd <jdaniel1127@...>
> ÂÂ
works great!
> --- In vantage@yahoogroups.com, Tony Hughes <thughes281@> wrote:
> > James,
> > ÂÂ
Â
works great!
> > James,
> > ÂÂ
Â
Â
works great!
> > James,
> > ÂÂ
Â
Â
works great!
> > James,
> > ÂÂ
OK, I went back to my notes from when I set this up (2 years ago) try this as well:
(When adding to group footer)
un-check "reset page number after" for group footer# 1b, and check "reset page number after" for the footer section with the terms.
I hope this helps.
Andy
> From: jdaniel1127@...
> ÂÂ
> From: "howco22" < agortman@... >
> ÂÂ
> works great!
> > > James,
> > > ÂÂÂ
> From: "jdaniel1127@..." <jdaniel1127@...>
> Â
> Â
> works great!
> > > James,
> > > ÂÂ
> > From: jdaniel1127@
> > Â
> > Â
> > works great!
> > > > James,
> > > > ÂÂ
James
jdaniel1127@...
> > > From: jdaniel1127@
> > > Â
> > > Â
> > > works great!
> > > > > James,
> > > > > ÂÂ
Ok,
> Thanks,
> James
> jdaniel1127@...
> > > > From: jdaniel1127@
> > > > Â
> > > > Â
> > > > works great!
> > > > > > James,
> > > > > > ÂÂ
> Ok,
> > Thanks,
> > James
> > jdaniel1127@
> > > > > From: jdaniel1127@
> > > > > Â
> > > > > Â
> > > > > works great!
> > > > > > > James,
> > > > > > > ÂÂ
> > Ok,
> > > Thanks,
> > > James
> > > jdaniel1127@
> > > > > > From: jdaniel1127@
> > > > > > Â
> > > > > > Â
> > > > > > works great!
> > > > > > > > James,
> > > > > > > > ÂÂ
