Crystal Reports problem
I know I tried setting the 'new page' on a couple of the lines and it didn't
work. But I will try it on a couple of others and see what happens. I
definitely set the suppress section when blank on all the lines.
Manasa Reddy
Sent: Wednesday, September 26, 2001 8:44 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Crystal Reports problem
I played around with it a bit but could not duplicate it. I am using a mix
of 8.0 and 8.5 so it is hard telling how this relates to 7.0. My only
guesses would be to look at the section formats to see if "new page" is
checked. Perhaps if this was set for the first group header the subsequent
ones would inherit this. This does not happen for me but 7.0 could be
different. Also watch the length of each subgroup header and suppress
sections when blank to avoid them exceeding the page length and forcing a
new page that way.
-Todd C.
Sent: Wednesday, September 26, 2001 7:41 AM
My traveler is still not working.......I created a new group for the OperSeq
and created several subgroup headers as well (just like the BOMSeq) and now
I get each section on a separate page (the header is separate, the raw
material is separate, and each operation sequence is separate).
Any other ideas? Anyone?
Thanks in advance,
Manasa Reddy
Sent: Monday, September 24, 2001 3:28 PM
Then I think you could do as I had suggested previously and move all the
fields from the group headers where they now reside into the new Operseq
header. One big group or possibly several sub group headers (A,B,C,D...) if
you want to conditionally print them as they are now (as in don't print
materials list if there are no materials). Follow the BOMseq header items
as an example for the Operseq group header. Sounds like you want it all so
it may be easier to create one big group header and always print everything.
Hope this is what you were looking for but it is just quick thoughts off the
top of my head (better thoughts than hair ;) ).
-Todd C.
Sent: Monday, September 24, 2001 3:12 PM
Maybe I am doing something wrong....but it is not working. Each operation
does come on separate pages, but not the rest of the information above the
Operations Section.
Here is what I would like to happen, in case I wasn't clear before (if it is
even possible):
On the job traveler (with bar codes on), I would like Job, Asm, Part and Rev
#, the Shipping Schedule, and The Raw Material Components on each page with
each operation sequence number on a separate page.
Manasa Reddy
Sent: Monday, September 24, 2001 1:24 PM
Just a guess but couldn't you insert a new group/sort for Operseq and force
a new page in the group header? You would want to delete or suppress the
group footer (or put the page skip there if you want the first oper with the
other header info).
-Todd C.
Sent: Monday, September 24, 2001 12:46 PM
Subject: [Vantage] Crystal Reports problem
We are on version 7.0 for Crystal.
For my traveler, I want my Job Operations to print on separate pages, but I
want everything above the Job Operation level to print on each page with
each Operation.
Does anyone know how to do this with Crystal?
I tried the print before and after, but all of the information (namely the
bar codes) above does not print for each page.
Thanks in advance,
Manasa Reddy
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=168643.1620686.3168692.1261774/D=egroupmai
l/S=1705007183:HM/A=799560/rand=471953494>
each Operation.
Thanks in advance,
Manasa Reddy
other header info).
-Todd C.
each Operation.
Thanks in advance,
Manasa Reddy
ADVERTISEMENT
Operations Section.
even possible):
Manasa Reddy
other header info).
-Todd C.
each Operation.
Thanks in advance,
Manasa Reddy
ADVERTISEMENT
-Todd C.
Operations Section.
even possible):
Manasa Reddy
other header info).
-Todd C.
each Operation.
Thanks in advance,
Manasa Reddy
ADVERTISEMENT
Thanks, Todd! That makes a lot more sense...I'll try it out today,
hopefully, and let you know if it worked!
Manasa Reddy
-Todd C.
Operations Section.
even possible):
Manasa Reddy
other header info).
-Todd C.
each Operation.
Thanks in advance,
Manasa Reddy
ADVERTISEMENT
Thanks in advance,
Manasa Reddy
-Todd C.
Operations Section.
even possible):
Manasa Reddy
other header info).
-Todd C.
each Operation.
Thanks in advance,
Manasa Reddy
ADVERTISEMENT
new page that way.
-Todd C.
Thanks in advance,
Manasa Reddy
-Todd C.
Operations Section.
even possible):
Manasa Reddy
other header info).
-Todd C.
each Operation.
Thanks in advance,
Manasa Reddy
ADVERTISEMENT
