Thanks again Vic! I think I will be able to make it work using formulas.
Â
Dustin Biniek
UMC, Inc.
DustinB@...
Sent: Monday, May 11, 2009 1:49:19 PM
Subject: RE: [Vantage] Crystal Reports - Subreport Shared Variables
Once you place the sub-report's result into the container report's shared variable, you can use it in other formulas. However, I don't believe you can use the Crystal Reports SUM or RT's.
Any usage of the returned variable's data must be used in another formula. However, using creative formulas you can simulate sum's.
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of melissa hietala
Sent: Monday, May 11, 2009 1:55 PM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] Crystal Reports - Subreport Shared Variables
Now that I was able to pass the variable from the sub-report to the main report, is it possible to do any kinda of summaries or running totals on the shared variable that is passed into the main report?
Â
Dustin Biniek
UMC, Inc.
DustinB@ultramc. com
____________ _________ _________ __
Sent: Monday, May 11, 2009 11:53:48 AM
Dustin,
You must make sure that you pass the variable back to the Parent report and then use your shared var in a section after the section where you bring back the sub-report var. See the site below. It gives you step-by-step directions
http://www.datamana gementgroup. com/Resources/ TrainersTalk/ trainerstalk_ howto_share_ subreport_ data_with_ main_report. asp
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf Of melissa hietala
Sent: Monday, May 11, 2009 12:47 PM
Subject: [Vantage] Crystal Reports - Subreport Shared Variables
I have a crystal report that has a subreport linked in it. I am able to pass a variable from the main report to the sub-report with the statement: Shared NumberVar X:= {invcdtl.unitprice} . Passing this variable from the main report to the sub-report works fine. However, is it possible to pass a variable from the SUB-report to the MAIN-report? I am using similar logic & formulas  but it doesn't seem to be working the way I would like. Any thoughts?
 Dustin Biniek
UMC, Inc.
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups. yahoo.com/ group/vantage/ files/.
(2) To search through old msg's goto: http://groups. yahoo.com/ group/vantage/ messages
(3) To view links to Vendors that provide Vantage services goto: http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Â
Dustin Biniek
UMC, Inc.
DustinB@...
Â
Dustin Biniek
UMC, Inc.
Dustin,
 Dustin Biniek
UMC, Inc.
