yes. declare both variables in the subreports as formula fields using the
following syntax
// In this example the variable is a number variable
shared global numberVar XXXX := the value ;
Then create formulas in the main report calling this same variable
// the variable name from subreport 1 in this example
shared global numberVar XXXX;
It's important to place the formula in the report (you can suppress printing if
necessary) or the variables will not work properly.
Crystal help has a pretty good section on variables. I refer to it all the time
as I confuse easily!
HTH,
Mike
____________________Reply Separator____________________
Subject: [Vantage] [OT] Crystal Reports question
Author: <vantage@yahoogroups.com>
Date: 7/9/2002 11:13 AM
Is it possible to pass a variable *back* from a sub-report to the main
report in Crystal? In other words:
Main Report
Sub-Report #1
Resulting Variable #1
Sub-Report #2
Resulting Variable #2
Main Report calculation, using Variables #1 & #2
Thanks in advance.
Malcolm Spann
MIS
Malmberg Engineering
(925) 606-6500 x19
Malcolm@...
following syntax
HTH,
Mike
Main Report
Sub-Report #1
Sub-Report #2
Thanks in advance.
Malcolm Spann
MIS
(925) 606-6500 x19
Malcolm@...
