DaveOlender
(Dave Olender)
September 14, 2021, 2:31pm
1
We would like to create a BAQ Report to show invoice totals for this year and last year.
We would like to prompt the user with a single “As Of Date” using a parameter and then use the parameter date to calculate back one year.
I do not see where I can use a Parameter in a Formula.
Is there some trick to this?
Thanks - DaveO
DaveOlender
(Dave Olender)
September 15, 2021, 11:40am
3
Mr. Prashanth: That is excellent - Thank you so much.
DaveO
DaveOlender
(Dave Olender)
September 28, 2021, 2:10pm
4
Mr. Prashanth: It looks like if you have a subreport in the query I am not allowed a reference to the parameters.
zwilli526
(Zack Williams)
September 28, 2021, 4:58pm
5
Make sure the parameter is marked “Mandatory”. I think that’s a requirement to use it in an expression.
DaveOlender
(Dave Olender)
September 28, 2021, 5:05pm
6
Mr. Zack: Thank you for the suggestion.
The “Mandatory” check did not allow me to see any of my my parameters.
However, i appreciate the suggestion - i did not think to try that.
DaveO
ckrusen
(Calvin Krusen)
September 28, 2021, 5:41pm
7
You may have to use Sub-query Criteria to apply a parameter.
EDIT
Whoops … I didn’t realize you wanted to use it in a formula.
DaveOlender
(Dave Olender)
September 28, 2021, 6:11pm
8
Mr. Calvin: Thank you for the reply.
Yes - i am prompting the operator for the “EndDate” and I need to calculate the “StartDate” based on the “EndDate”.
Since i am unable to reference the EndDate prompt it is turning out very hard to calculate the start date.
Thank you again,
DaveO
ckrusen
(Calvin Krusen)
September 28, 2021, 6:22pm
9
Are you calculating the start date for displaying purposes? Or is it for filtering the results of the subquery?
If it is the later, you could add subquery criteria with an expression, to filter subquery records that are sent to the top level query.
edit
And did you try just using the parameter in the format shown for the top level (even though it’s not in the expression builder). @endate
(or whatever your parameter name is)
