Data directives are really not much more than the old alert programs on a
BAM, but with the front-end interface similar to method directives.
Kevin
Rob Bucek
Sent: Friday, January 06, 2012 4:56 PM
Subject: RE: [Vantage] Re: Customization Field help
Curious, im not on 9 yet so im not up to speed on data directives, by
reading what you said, it might be possible to fire a data directive when
MRP creates new jobs?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...
<mailto:1.234354861%40web65412.mail.ac4.yahoo.com> ]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Behalf Of Kevin Simon
Sent: Friday, January 06, 2012 1:41 PM
I would probably put this code in as a data directive, not as a method
directive. Use the same code, only on the data directive have the condition
be where there's at least one added row.
If it's a method directive, it will only fire when the JobEntry.Update
method fires. So, if a job gets added outside of Job Entry (example: MRP,
Order Job Wizard), then this method would not get triggered.
Kevin Simon
SimsTrak Consulting
<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
Greg Payne
Sent: Friday, January 06, 2012 12:43 AM
Pre-Processing Method directive on JobEntry.Update
Condition: the JobHead.Character01 field of the changed row is equal to the
"" expression
Action: synchronously execute ABL Code .. record nothing
Paste this into the execute code below window.
/*Set Jobhead Character01 to Part Character04*/
for each ttJobHead no-lock, each Part no-lock where Part.company =
ttJobHead.Company and Part.Partnum = ttJobHead.PartNum and Part.Character04
Assign ttJobHead.Character01 = Part.Character04.
End.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Anon
Sent: Thursday, January 05, 2012 1:36 PM
Subject: [Vantage] Re: Customization Field help
I'm not very good with BPMs is there any more direction you can offer on
this particular case?
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com>, "Vic Drecchio"
If the Character04 field is not blank on the part data then it equates the
Part.Character04 field to the JobHead.Character01 field. What would be my
best way of going about this?
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is
privileged and confidential. It is intended only for the exclusive use of
the addressee. If the reader of this message is not the intended recipient,
or the employee or agent responsible for delivering it to the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this communication is strictly prohibited. If you have received
this communication in error, please notify us at (727) 578-6258 and
immediately delete the communication.
"This (document/presentation) may contain technical data as defined in the
International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of
this material is restricted by the Arms Export Control Act (22 U.S.C. 2751
et seq.) and may not be exported to foreign persons without prior approval
form the U.S. Department of State."
Kevin
Rob Bucek
Rob Bucek
FAX: (715)284-4084
Kevin Simon
SimsTrak Consulting
Behalf Of
Greg Payne
"" expression
End.
Behalf Of Anon
> BPM would do it. If you are SQL, then you could also do a trigger.
> From: Anon
> Sent: Thursday, January 05, 2012 9:54 AM
> Subject: [Vantage] Customization Field helpfield of the Job header is not blank it goes and gets the data for the part.
> Looking to do the following. A job is created or loaded. If the partnum
>________________________________
> No virus found in this message.
> Checked by AVG - www.avg.com<http://www.avg.com>
> Version: 2012.0.1901 / Virus Database: 2109/4724 - Release Date: 01/05/12
