What type of customizations can CREATE a NEW record?
Thanks everyone for all your posts. We are going to get some other quotes.
Mike.. so instead of "pushing out" from the invoice to create a new misc. packer record and populate it, if the "create" new record does not work (as mentioned by others) then create the misc packer manually and "pull in" the data needed from the invoice (header and lines).
A bit more work for the user but a reasonable compromise. We would do as you suggest if the full blown automation method does not work (without getting into service connect or database license(SDK)).
PS: The next step in this project (did not want to complicate the thread) will be to automate the BOL from the misc. packer as that too is a manual & partially redundant data entry process.
PSS: I'll make sure I post our solution to the group when completed..along with some very nice Crystals we are doing to print an invoice/misc.packer and BOL.
Matt Sweny
Modern Industries Inc.
814-455-8061
matts@...<mailto:matts@...>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Anstey
Sent: Thursday, November 04, 2010 8:48 AM
Subject: RE: [Vantage] Re: What type of customizations can CREATE a NEW record?
Why don't you add a user defined field to enter the misc invoice number
and line as a text string on the Misc shipment screen.
Then customize the misc packer screen to fire a process like
CalculateWeight (don't know if this one will work but you should be able
to find one that will) when you update your user defined field. (You
would use the form event wizard to do that).
Once that is done write a bpm with ABL code to fire post process that
reads in your invoice # string (e.g. 10000)
Next read the invoice head (make sure you use NO-LOCK), and assign the
values you want to the ttMscShipHed record.
You could then do the same thing on the Lines screen but enter the
invoice # and line # eg. (10000-1) and use the Progress ENTRY() function
to separate out the invoice # and the line, then read the invoice detail
record and assign the values you want to the ttMscShipDtl record.
This avoids service connect and the requirement to have a database
license that allows addition of records.
Obviously you would need to know how to write simple Progress code to
retrieve records, and how to manipulate tt records, but this really
isn't that hard.
I would allow a day at most for this to be completed.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Kevin Simon
Sent: Thursday, November 04, 2010 8:31 AM
record?
Matt,
My biggest concern was your initial post that this could only be done in
Service Connect. Service Connect is a great tool and has a lot of
applications, I just don't think this is one of them. This sounds like a
fairly reasonable customization. The 3-5 days seems a little high, at
first
blush this looks to be about a day or two. However, that being said,
there's always things that get forgotten that come up, and there's
always
the extra time you build in to do proper error handling. Your consultant
may have built that fudge factor in already (think about how long it
takes,
double it, add one, etc.) and given you a "worst case" ballpark.
Kevin Simon
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Sweny, Matt
Sent: Wednesday, November 03, 2010 1:13 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
record?
Ross, and others who have posted(Kevin, Jeff, Waffqle)
Did not want to bore everyone with the details but specifically.....
1st form screen = AP Invoice(debit memo)(aka misc. invoice)
2nd form screen = Misc. Shipment Entry (aka misc. packer)
In vantage 8.03.305 an AP misc. invoice (debit) is created for a
supplier,
frequently we are returning purchased product to the supplier that is
MRO(indirect) kind of stuff like office supplies, maintenance
supplies... so
we do not want to use the quality functionality to return this kind of
thing
because that functionality is cumbersome. We would like to create a
vantage
misc. packing slip. Now in vantage if you have misc. transactions there
is
duplicate data entry. Enter the data in misc. invoice(debit) then go
over to
misc. packer and enter again. We are trying to reduce data entry to
speed up
and lean the process.
In other words there are redundant fields that need to be entered in the
misc. invoice(debit) and packing slip such as supplier code, part
number,
etc. (plus some UD fields we are adding to the AP misc. Invoice(debit)
that
exits in the misc. packer such as PO# etc.)
So we have some vantage native fields such as supplier number and part
number that we want to (with the click of a customized button on the
debit
memo header)...... open/create a "new" record in misc. packer then
populate
the packer with some of the data from the AP misc. invoice(debit) such
as
header info. like supplier number etc., then have the customization
create a
line in the misc. packer for every line in the AP misc. invoice (debit).
Do these specifics mentioned above still sound like average
customizations
like screen and bpm's can be used or would service connect be required?
I
hope I explained it clear enough.
Does 3-5 days of programming (service connect or average customizations)
sound reasonable for this kind of customization?
PS: why would we need to set up a UD table to create the new record?
Just
want to create the new record in the Misc. Shipment Entry table native
in
vantage?
Regards,
Matt
Behalf Of rossh777
Sent: Wednesday, November 03, 2010 12:25 PM
Subject: [Vantage] Re: What type of customizations can CREATE a NEW
record?
Matt,
Maybe I am misunderstanding the spec, but it doesn't sound correct. What
are
the first and second forms/screens? Can you say a little more about it?
If
it is easier to contact me offline, feel free.
If I am tracking your needs accurately, you can do that with an average
customization. You just use an adapter to create a new record in one of
your
UD(?) tables when the button is clicked, transfer the first form field
values to the new second form database row, and save/update. Then, open
up
the new form calling the new record created.
Ross
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com>, "Sweny, Matt" <matts@...> wrote:
> Thanks Waffqle & Bruce
> We have a need to create a button on a form (in vantage) that when
clicked
opens a 2nd form (in a different vantage screen) and creates a new
record in
the 2nd form and copies 4-6 fields of information from the 1st form into
the
new record then saves the record.
> Our consultant is telling us ONLY Service Connect can do that and its
going to take 3 - 5 days of programming time to do the Service Connect.
> Does this sound right?
> Matt
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On
Behalf Of cooner_55421
> Sent: Wednesday, November 03, 2010 11:50 AM
record?
> Matt,
> I think they mean the ONLY SUPPORTED customization method.
> I've used Pervasive to add records, mostly parts and methods.
> I've even put records in using MS-Access & ODBC.
> The problem with this is all the time spent mapping the tables that
have
to be populated. If I remember, just for a part it's six tables.
> Service Connect is easier and maybe even cheaper in the long run.
> Bruce
> -----Original Message-----
On
Behalf Of Waffqle Driggers
> Sent: Wednesday, November 03, 2010 11:37 AM
> Subject: Re: [Vantage] What type of customizations can CREATE a NEW
record?
> I should add though, it is a great deal easier to do it with Service
Connect
> if you don't have someone who can program.
> On Wed, Nov 3, 2010 at 11:35 AM, Waffqle Driggers <waffqle@...> wrote:
> > BPM and Customizations can do all that. We use that functionality
> > extensively; I'm sure many others do as well.
> > We sync parts, customers and orders from Epicor with another system
and
we
> > don't use service connect at all.
> > On Wed, Nov 3, 2010 at 11:29 AM, Matt <matts@...> wrote:
> >> We are being told that the ONLY customization method available in
vantage
> >> 8.xx or 9.xx that will "create" a "new" record is Service Connect.
Is
this
> >> true?
> >> Can BPM's or screen customizations create a record to the table(s)
or
are
> >> they only tools that can manipulate a record that already exists?
> >> Any guildance would be appreciated.
> >> Matt
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder
and
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> Disclaimer:
> This email transmission and any attachments to it are intended solely
for
the use of the individual or entity to whom it is addressed and may
contain
confidential and privileged information. If you are not the intended
recipient, your use, forwarding, printing, storing, disseminating,
distribution, or copying of this communication is prohibited. If you
received this communication in error, please notify the sender
immediately
by replying to this message and delete it from your computer.
Disclaimer:
for
contain
immediately
Disclaimer:
This email transmission and any attachments to it are intended solely for the use of the individual or entity to whom it is addressed and may contain confidential and privileged information. If you are not the intended recipient, your use, forwarding, printing, storing, disseminating, distribution, or copying of this communication is prohibited. If you received this communication in error, please notify the sender immediately by replying to this message and delete it from your computer.
We are being told that the ONLY customization method available in vantage 8.xx or 9.xx that will "create" a "new" record is Service Connect. Is this true?
Can BPM's or screen customizations create a record to the table(s) or are they only tools that can manipulate a record that already exists?
Matt
We sync parts, customers and orders from Epicor with another system and we
> true?
> Matt
I should add though, it is a great deal easier to do it with Service Connect
>> true?
>> Matt
We have a need to create a button on a form (in vantage) that when clicked opens a 2nd form (in a different vantage screen) and creates a new record in the 2nd form and copies 4-6 fields of information from the 1st form into the new record then saves the record.
Our consultant is telling us ONLY Service Connect can do that and its going to take 3 - 5 days of programming time to do the Service Connect.
Matt
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cooner_55421
Subject: [Vantage] Re: What type of customizations can CREATE a NEW record?
Matt,
The problem with this is all the time spent mapping the tables that have to be populated. If I remember, just for a part it's six tables.
Bruce
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Waffqle Driggers
Subject: Re: [Vantage] What type of customizations can CREATE a NEW record?
>> true?
>> Matt
Disclaimer:
If you do it through customizations or BPM you should still be hitting the
business logic (unless you're doing something bad) so you don't have to
worry about all the tables so much.
I know pulling the BO's into outside software isn't really supported, but to
the best of my knowledge BPM/customization is supported.
On Wed, Nov 3, 2010 at 11:50 AM, cooner_55421 <cooner_55421@...>wrote:
> Matt,
> Bruce
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, "Matt" <matts@...>
> true?
> > Matt
Matt,
Maybe I am misunderstanding the spec, but it doesn't sound correct. What are the first and second forms/screens? Can you say a little more about it? If it is easier to contact me offline, feel free.
If I am tracking your needs accurately, you can do that with an average customization. You just use an adapter to create a new record in one of your UD(?) tables when the button is clicked, transfer the first form field values to the new second form database row, and save/update. Then, open up the new form calling the new record created.
Ross
> Matt
> Matt,
> Bruce
> >> true?
> >> Matt
> Disclaimer:
There are tons of adapters you can add to a customization to create new records such as PartAdapter, CostAdjustmentAdapter, LotSelectUpdateAdapter, SalesOrderAdapter, etc. Programming in Visual Basic or C is required.
Service Connect is powerful but it is very, very confusing.
Epicor has a tool called DMT (Data Management Tool) which is very easy to use and has many tables you can add records to. Simply select the method, (Examples: Part, PartLot, CostAdjustment, Qty Adjustment, Customer, JobHead, Job Material), select the spread sheet your data is in, and tell it to process. It is not the fastest thing in the world but is very user friendly. It creates a CSV file of the records that fail so you can edit them to try again. You can also build a template excel file from inside DMT.
EPICOR has versions of DMT for 9.04 and 9.05, not sure about 8.??
Jeff Sanders
> Matt
Matt,
I've done a ton of Service Connect workflows and customizations, and based
upon your brief description, I would definitely go the customization route.
Service Connect wouldn't be able to handle the capture of information, you'd
need to develop a customization to capture the information anyway. At that
point, your 75% of the way there, adding Service Connect to the picture just
adds a whole layer of complexity you don't need.
Sounds like you need to look at a new consultant.
Hope that helps,
Kevin Simon
SimsTrak Consulting
Sweny, Matt
Sent: Wednesday, November 03, 2010 11:54 AM
Subject: RE: [Vantage] What type of customizations can CREATE a NEW record?
Matt
Matt,
Bruce
this
>> true?
>> Matt
Disclaimer:
Bruce,
Service Connect is no more supported than the customization. Either one, if
you run into issues on the logic side of it, you're going to get the "you'll
need to contact custom programming" answer from tech support.
Kevin
cooner_55421
Matt,
Bruce
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Matt"
true?
> Matt
In vantage 8.03.305 an AP misc. invoice (debit) is created for a supplier, frequently we are returning purchased product to the supplier that is MRO(indirect) kind of stuff like office supplies, maintenance supplies... so we do not want to use the quality functionality to return this kind of thing because that functionality is cumbersome. We would like to create a vantage misc. packing slip. Now in vantage if you have misc. transactions there is duplicate data entry. Enter the data in misc. invoice(debit) then go over to misc. packer and enter again. We are trying to reduce data entry to speed up and lean the process.
In other words there are redundant fields that need to be entered in the misc. invoice(debit) and packing slip such as supplier code, part number, etc. (plus some UD fields we are adding to the AP misc. Invoice(debit) that exits in the misc. packer such as PO# etc.)
So we have some vantage native fields such as supplier number and part number that we want to (with the click of a customized button on the debit memo header)...... open/create a "new" record in misc. packer then populate the packer with some of the data from the AP misc. invoice(debit) such as header info. like supplier number etc., then have the customization create a line in the misc. packer for every line in the AP misc. invoice (debit).
Do these specifics mentioned above still sound like average customizations like screen and bpm's can be used or would service connect be required? I hope I explained it clear enough.
Does 3-5 days of programming (service connect or average customizations) sound reasonable for this kind of customization?
PS: why would we need to set up a UD table to create the new record? Just want to create the new record in the Misc. Shipment Entry table native in vantage?
Regards,
Matt
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of rossh777
Matt,
Ross
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Sweny, Matt" <matts@...> wrote:
> Matt
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of cooner_55421
> Matt,
> Bruce
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Waffqle Driggers
> >> true?
> >> Matt
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> Disclaimer:
Disclaimer:
Easy as pie. We actually have a somewhat similar RMA customization in place
already.
> vantage?
> Regards,
> Matt
> From: vantage@yahoogroups.com <vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf Of rossh777
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> Matt,
> Ross
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com><mailto:
> vantage%40yahoogroups.com <vantage%2540yahoogroups.com>>, "Sweny, Matt"
> > Matt
> > From: vantage@yahoogroups.com <vantage%40yahoogroups.com><mailto:
> vantage%40yahoogroups.com <vantage%2540yahoogroups.com>> [mailto:
> vantage%40yahoogroups.com <vantage%2540yahoogroups.com>>] On Behalf Of
> cooner_55421
> > To: vantage@yahoogroups.com <vantage%40yahoogroups.com><mailto:
> record?
> > Matt,
> > Bruce
> Waffqle Driggers
> record?
> Connect
> we
> vantage
> this
> > >> true?
> are
> > >> Matt
> > Disclaimer:
> Disclaimer:
Matt,
You don't need a UD table. I didn't know what second form you were using and wrongly assumed it to be a UD table.
That is still a pretty straightforward customization and can be done without Service Connect. Actually, I wouldn't have even thought of using SC for that application.
Ross
> Regards,
> Matt
> Matt,
> Ross
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Sweny, Matt" <matts@> wrote:
> > Matt
> > Matt,
> > Bruce
> > >> true?
> > >> Matt
> > Disclaimer:
> Disclaimer:
I'm NOT a programmer, so service connect is the first tool I would look
to use for something like that. Probably a BPM fired workflow based on
your description, with the BPM and any MINOR customizations, to include
the Service connect work flow..any more than one or two days and they
are hosing you... I have similar concepts in action and that's all it
took me to bang them out.. Others with different toolsets can get it
done in a different fashion.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Sweny, Matt
Sent: Wednesday, November 03, 2010 12:13 PM
record?
native in vantage?
Regards,
Matt
Behalf Of rossh777
record?
Matt,
Ross
> Matt
record?
> Matt,
> Bruce
record?
Connect
and we
vantage
Is this
> >> true?
or are
> >> Matt
<http://groups.yahoo.com/group/vantage/files/> <
> Disclaimer:
your computer.
Disclaimer:
your computer.
Matt,
fairly reasonable customization. The 3-5 days seems a little high, at first
there's always things that get forgotten that come up, and there's always
may have built that fudge factor in already (think about how long it takes,
Kevin Simon
Sweny, Matt
record?
vantage?
Regards,
Matt
Behalf Of rossh777
Matt,
Ross
> Matt
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
record?
> Matt,
> Bruce
record?
Connect
we
vantage
this
> >> true?
are
> >> Matt
> Disclaimer:
Disclaimer:
isn't that hard.
Of Kevin Simon
record?
Matt,
first
always
takes,
Kevin Simon
Behalf Of
Sweny, Matt
record?
supplier,
supplies... so
thing
vantage
is
over to
speed up
number,
that
debit
populate
as
create a
customizations
I
Just
in
vantage?
Regards,
Matt
Behalf Of rossh777
record?
Matt,
are
If
your
up
Ross
clicked
record in
the
> Matt
On
record?
> Matt,
have
> Bruce
On
record?
Connect
and
we
vantage
Is
this
> >> true?
or
are
> >> Matt
have
and
> Disclaimer:
for
contain
immediately
Disclaimer:
for
contain
immediately
