Hi,
I made a customization on Customer tracker and make it default customization under Financial Management/AR/Operation in Menu Maintenance.
My question is that is there an easy way to deploy to all Customer tracker regardless of the path open it?
Or I need to go into each Menu ID to update the Customization option? As far as I know there are 7 paths.
You can do a uBAQ, or (as I do) I run an update using DMT.
